Microcontrollers in Sinhala (???????? ????????????????????)
Post by Saman » Sat Jun 30, 2012 1:53 am
This is PIC Microcontroller programing lesson series published on Vidusara newspaper. All lessons available in Sinhala medium and PDF version.
To do following experiments, you can find products from TRONIC.LK.
Introduction to Microcontrollers
1.1.pdf
(606.44 KiB) Downloaded 25382 times
I. Internal Architecture
I/O Ports Fetch, Decode, and Execute
2.2.1.pdf
(386.03 KiB) Downloaded 19601 times
Controlling and processing unit
2.2.2.pdf
(190.71 KiB) Downloaded 12083 times
II. Softwares used for Programming Microcontrollers
Compilers and Integrated Development Environments
3.1.pdf
(390.29 KiB) Downloaded 13203 times
How to build your own JDM Programmer
3.2.pdf
(839.82 KiB) Downloaded 12572 times
3.2.1.pdf
(516.73 KiB) Downloaded 10567 times
Hardware needed for Programming
3.2.2.pdf
(453.15 KiB) Downloaded 10480 times
Program using ICPROG Software
3.3.pdf
(615.29 KiB) Downloaded 10335 times
III. Build your first microcontroller based circuit
Typical microcontroller assembly circuit diagram
4.1.pdf
(472.21 KiB) Downloaded 10383 times
Special Function registers of the Microcontroller PIC16F84A
4.2.pdf
(408.27 KiB) Downloaded 9518 times
Creating your first assembly code
4.3.pdf
(343.92 KiB) Downloaded 9684 times
How to write assembly code in MPLAB
4.4.pdf
(865.99 KiB) Downloaded 10227 times
More on MPLAB
4.5.pdf
(550.35 KiB) Downloaded 12882 times
How to simulate using MPLAB SIM
4.6.pdf
(1.09 MiB) Downloaded 17398 times
IV. LED Pattern generators
Assembly code for driving 8 LEDs (I)
5.1.pdf
(340.11 KiB) Downloaded 9621 times
Assembly code for driving 8 LEDs (II)
5.2.pdf
(374.57 KiB) Downloaded 12383 times
Driving 40 LEDs using PORT multiplexing (8x5)
5.3.pdf
(416.27 KiB) Downloaded 9105 times
How to display a Character using 8x5 LED matrix
5.4.pdf
(388.94 KiB) Downloaded 8278 times
V. Seven Segment Displays
Driving segments using PORT-B I/O
6.1.pdf
(367.76 KiB) Downloaded 8228 times
Basic counter circuit (I)
6.2.pdf
(388.81 KiB) Downloaded 7930 times
0 - 100 up counter using two SSD (I)
6.3.1.pdf
(420.05 KiB) Downloaded 7818 times
0 - 100 up counter using two SSD (II)
6.3.2.pdf
(28.32 KiB) Downloaded 6116 times
Usage of interrupts
6.4.pdf
(361.73 KiB) Downloaded 7667 times
Practical usage of Interrupts
6.5.pdf
(376.43 KiB) Downloaded 7524 times
External Interrupts
6.6.pdf
(409.06 KiB) Downloaded 7660 times
VI. Connecting a microcontroller with the PC
PC Serial port overview
7.1.pdf
(532.8 KiB) Downloaded 7354 times
Logic level translation using MAX 232 IC
7.2.pdf
(386.52 KiB) Downloaded 7221 times
Assembly code for controlling USART module (I)
7.3.pdf
(367.06 KiB) Downloaded 7253 times
Assembly code for controlling USART module (II)
7.4.pdf
(363.05 KiB) Downloaded 6543 times
VII. Analog to Digital conversion
Temperature Logger using LM35
8.1.pdf
(357.93 KiB) Downloaded 6758 times
Importance of Quantization error and Sampling rate
8.2.pdf
(355.88 KiB) Downloaded 6629 times
PIC16F877A ADCON0 and ADCON1register
8.3.pdf
(485.51 KiB) Downloaded 6622 times
A/D, show results using SSD
8.4.pdf
(364.13 KiB) Downloaded 6585 times
Assembly code for A/D conversion (I)
8.5.1.pdf
(371.56 KiB) Downloaded 6362 times
Assembly code for A/D conversion (II)
8.5.2.pdf
(77.44 KiB) Downloaded 6036 times
Send A/D converted data through RS-232
8.6.pdf
(372.4 KiB) Downloaded 6349 times
VIII. Liquid Crystal Displays
Types of LCDs
9.1.pdf
(420.11 KiB) Downloaded 6434 times
Running a LCD module using PIC16F84A (I)
9.2.pdf
(493.08 KiB) Downloaded 6670 times
Running a LCD module using PIC16F84A (II)
9.3.pdf
(475.97 KiB) Downloaded 6817 times
Running a LCD module using PIC16F84A (III)
9.4.pdf
(369.8 KiB) Downloaded 6529 times
IX. Number representations
Introduction to Binary, Octal and Hex number systems
10.1.pdf
(124.72 KiB) Downloaded 5958 times
Logic gates and Boolean algebra
10.2.pdf
(371.05 KiB) Downloaded 6297 times
Boolean algebra and Registers
10.3.pdf
(374.92 KiB) Downloaded 6260 times
Communication using Ascii codes
10.4.pdf
(381.97 KiB) Downloaded 6282 times
X. DC Motor controlling
Controlling a DC motor using H-Bridge IC L298
11.1.pdf
(362.1 KiB) Downloaded 6591 times
Control rotation speed, rotation direction using Microcontroller
11.2.pdf
(366.71 KiB) Downloaded 6261 times
Connecting the DC motor controller to PC
11.3.pdf
(69.06 KiB) Downloaded 5690 times
DC motor control according to the user press buttons
11.4.pdf
(581.05 KiB) Downloaded 6166 times
Pulse Width Modulation (PWM)
11.5.pdf
(401.43 KiB) Downloaded 6271 times
Calculating the DC Motor rotation speed (RPM)
11.6.pdf
(270.57 KiB) Downloaded 7237 times
Dynamic control using feedback loops
11.7.pdf
(495.88 KiB) Downloaded 6320 times
XI. Remote controllers numbering
The electromagnetic spectrum
12.1.pdf
(528.09 KiB) Downloaded 6235 times
Infrared remote controllers
12.2.pdf
(368.72 KiB) Downloaded 6024 times
IR Sensors
12.3.pdf
(157.1 KiB) Downloaded 5924 times
How to capture the IR receiver signal using Microcontroller
12.4.pdf
(725.06 KiB) Downloaded 6103 times
Decoding IR Signals (I)
12.5.pdf
(342.98 KiB) Downloaded 5898 times
Decoding IR Signals (II)
12.6.pdf
(55.61 KiB) Downloaded 5318 times
Decoding IR Signal algorithm
12.7.pdf
(122.25 KiB) Downloaded 5729 times
XII. Data transfer between digital circuits
Serial Peripheral Interface (I)
13.1.pdf
(64.92 KiB) Downloaded 5427 times
Serial Peripheral Interface (II)
13.2.pdf
(60 KiB) Downloaded 5274 times
Nokia 3310 LCD Driving using SPI (I)
13.3.pdf
(126.38 KiB) Downloaded 5637 times
Nokia 3310 LCD Driving using SPI (II)
13.4.pdf
(182.49 KiB) Downloaded 5574 times
Connecting a Nokia 3310 LCD to PIC16F877A
13.5.pdf
(506.51 KiB) Downloaded 6003 times
Assembly code for LCD driving (I)
13.6.pdf
(68.36 KiB) Downloaded 5429 times
Assembly code for LCD driving (II)
13.7.pdf
(58.49 KiB) Downloaded 5230 times
Sinhala characters in a Nokia 3310 LCD
13.8.pdf
(87.38 KiB) Downloaded 5398 times
Animation effects with Nokia 3310 LCD
13.9.pdf
(75.56 KiB) Downloaded 5253 times
XIII. How to use high level languages
Introduction
14.1.pdf
(70.15 KiB) Downloaded 5443 times
C code for blinking a LED
14.2.pdf
(406.06 KiB) Downloaded 6080 times
C code for driving 8 LEDs (I)
14.3.pdf
(415.64 KiB) Downloaded 5974 times
Driving 40 LEDs using PORT multiplexing (8x5) (I)
14.4.1.pdf
(701.25 KiB) Downloaded 6100 times
Driving 40 LEDs using PORT multiplexing (8x5) (II)
14.4.2.pdf
(38.58 KiB) Downloaded 5193 times
14.5.pdf
(398.73 KiB) Downloaded 5800 times
14.6.pdf
(84.76 KiB) Downloaded 5351 times
14.7.pdf
(395.87 KiB) Downloaded 5930 times
14.8.pdf
(397.12 KiB) Downloaded 6046 times
External Interrupts
14.9.pdf
(270.52 KiB) Downloaded 5866 times
14.10.pdf
(112.57 KiB) Downloaded 5680 times
Driving Liquid Cristal Displays
14.11.pdf
(430.59 KiB) Downloaded 5858 times
End of uC Series
14.12.pdf
(59.88 KiB) Downloaded 5465 times
XIV. Global Positioning System (GPS)
Introduction to Global Positioning
15.1.pdf
(368.18 KiB) Downloaded 5908 times
GPS Receivers
15.2.pdf
(159.87 KiB) Downloaded 5811 times
GPS Errors
15.3.pdf
(83.37 KiB) Downloaded 5410 times
Differential GPS
15.4.pdf
(147.4 KiB) Downloaded 6489 times
TRONICLK
Contact:
Re: Microcontrollers in Sinhala (???????? ????????????????????)
Post by TRONICLK » Sun Sep 16, 2012 1:40 pm
You can buy all these robot accessories, development boards, modules and sensors such as acceleration, gyroscope, ultrasonic distance measurement sensors, etc..., electronic components directly from TRONIC.LK.
You can pay by credit cards, PayPal, Dialog eZ cash, bank transfer, etc... and get all of them delivered to your doorstep.
