Easy Integrating GPS Module
Magneto
Post by Magneto » Wed Feb 03, 2010 8:50 am
TIM-LF GPS Receiver Module is a easy to integrate GPS module with microcontrollers. This unit is from Ublox.
This has serial interface to integrate with a microcontroller and we can initialise the GPS module to work upto 115200 bps.
This is the data sheet
TIM-LF_Data_Sheet(GPS.G3-MS3-03017).pdf
(198.13 KiB) Downloaded 715 times
Herath
Re: Easy Integrating GPS Module
Post by Herath » Thu Dec 02, 2010 4:59 am
GPS Module seems to be operating at 3.3V. If I use a MCU with 5V high logic level.Will I have to use logic level conversion?.
I think I am going to need conversion. :?:
Post by Neo » Thu Dec 02, 2010 12:22 pm
MAX3232 will do the job (not MX232).
