<?php
// this script will delete all your php.ini files
// full path to the location of your home directory
$path = "/home/" . get_current_user() . "/public_html";
// change nothing below this line
function search($dir) {
foreach(scandir($dir) as $filename) {
if ( $filename !== '.' AND $filename !== '..' AND is_dir("$dir/$filename") ) {
$path = $dir."/".$filename;
$target = $path . "/php.ini";
if (file_exists($target)) {
if (unlink($target)) echo "Deleted - $target <br>"; else echo "<b>Delete failed for $target </b><br>";
search($path);
echo "Deleting - $target <br>";
if (!unlink($target)) echo "<b>Delete failed for $target </b><br>";
search($path);
echo "<br>Done.";
