Upon completion, you will be able to save files back to the root of your Flash Drive (which is mounted as /cdrom) while your running from Ubuntu. Save your documents, photos, movies, mp3's, special configuration files etc… back to the Flash drive. In addition you can add files while running from Windows and then access those files again while running from Linux or vice versa.
The following solution should work for Ubuntu, Kubuntu, Linux Mint etc. Pretty much any Ubuntu derived compilation.
How to edit the Casper script to allow read and write access to the entire USB device:
- Boot from your previously created USB Ubuntu Flash Drive
- Open a terminal and type sudo su (to become root)
- Type mkdir /projectaccess (to make our project directory)
- Type cd /projectaccess (to change to the project directory)
- Type gzip -dc /cdrom/casper/initrd.gz | cpio -i (to extract the initrd.gz)
- Type gedit scripts/casper (to edit the casper script)
- From gedit, find the following section of code:
home_snapshot_label="home-sn" - Just below it add the following code:
mountmode="ro,noatime" - Now find the following section of code:
IGNORE_UUID="Yes" ;; - Just below it add the following code:
# New command line parameter to select the base device mount mode basemountmode=*) mountmode="${x#basemountmode=}";; - Now find the following section of code:
if is_supported_fs ${fstype}; then - and (as a single line of code) change the next line to:
mount -t ${fstype} -o ${mountmode} "${devname}" $mountpoint || continue - Save the file and return to the open terminal
- From the terminal type find . | cpio -o -H newc | gzip -9 > initrd.gz (to zip the new initrd.gz file)
- Type cp initrd.gz /cdrom/casper
- Type gedit /cdrom/syslinux/text.cfg
- On the first append line, replace the following section:
initrd=/casper/initrd.gz - With the following section (as a single line):
initrd=/casper/initrd.gz basemountmode=ro,noatime,uid=999,gid=999 - Save the file and exit the editor
- Reboot your computer and proceed to boot from your USB Flash Drive again
