A trouble with JDM programmer
Re: A trouble with JDM programmer
Post by Rksk » Fri May 07, 2010 6:55 pm
Hi all,
now i have a ney 16F877A chip with thankz again to robot.lk.
now,
when i click on PROGRAM ALL in winpic800, the led on jdm pro. is blinking but it gets same errors wich i have posted at the start of this topic. can any one help me?
thankz
Post by Rksk » Mon May 10, 2010 8:27 pm
Dear neo,
why don't you help me?
my brother also interested in this feild. if you can give some help, he will can make your donation usefull.
B.R.
Thankz
Post by Neo » Tue May 11, 2010 10:30 am
Open WinPic, click on Settings in the Toolbar and see whether you have the settings as in the following screenshot.
You might have different configuration here.
Reason: Edited with updated image
Post by Rksk » Tue May 11, 2010 3:16 pm
Hi,
above settings are alredy ok.
B.R.
Thanks.
Post by Neo » Tue May 11, 2010 4:12 pm
With these settings, is it still not working ?
Post by Rksk » Tue May 11, 2010 5:25 pm
yes, its still does not work.
Magneto
Post by Magneto » Tue May 11, 2010 9:33 pm
Hi friend ,
There is some correction has to done in above configuration diagram.
Under Osc , you have to select XT , not RC. If you select RC , it will take clock pulses from Internal oscillator.
Microcontroller taking clock pulses , from our external Crystal , only if we select XT.
Regards
Post by Neo » Wed May 12, 2010 12:55 am
I have updated the above image according to Magneto's note.
RKSK, can you confirm it is working now?
Post by Rksk » Wed May 12, 2010 5:55 am
Still, it doesn't work.
BR.
Post by Rksk » Wed May 12, 2010 11:11 pm
Neo,
still, is there port problem in my computer?
is there any way to programe a pic without veryfying, in Winpic800?
B.R.
