How to start with Microcontrollers
Post by Neo » Mon Mar 29, 2010 8:43 pm
1. Read some preliminary tutorials
2. Hardware requirements
3. Software requirements
4. Configure MP LAB and HI-TECH C compiler
5. Save 4 source files to your disk
6. Create a project with MP LAB
7. Burning the Hex file to Microcontroller
8. Running your first microcontroller program
I was asked more than 100 times about this topic so I thought to write a little article on how to start working with microcontrollers. I'll be using Microchip PIC16F877 microcontroller for my explanation due to high availability.
TRONIC.LK
    First thing is, read the following articles and try to understand as much as possible. These will give you a brief idea on what is a microcotroller and for what purposes we use them.
    Introduction to Microcontrollers
    PIC16F84 Tutorial
    I agree with you, these can be a little complicated for starters, but I think that's okay for now.
    1. PC running Windows with a serial port (For JDM programmer or USB for PICKIT2)
    2. PIC programmer
      You can either buy one or build one your own.
      You can fins a PIC programmer from TRONIC.LK or build your own one such as JDM programmer or PICKIT2.
      Circuit diagram can be found here.
      Multi PIC programmer
      PICKIT2 or 3 can be used not only to program but also to debug as well.
    3. Custom PCB for your requirement
      You may use a PIC mini development board or else assemble the circuit used in this tutorial in a Breadboard like the one below.
      First have a look at the pin diagram of PIC16F877
      You can see that the PIC16F877 has many number of I/O ports that can be used for number of purposes.
      For this tutorial lets use a single LED circuit as in the schematic diagram below. We are going to blink this LED every few seconds.
      PIC Power Supply
      LED Circuit
      Note: Use a 4 MHz crystal oscillator insted of the 20 MHz one in the diagram (denoted as XTAL20mhz)
    1. Microchip MPLAB IDE
      You can download Microchip's MPLAB IDE/assembler for free.
    2. C/C++ compiler
      Most of us choose C/C++ rather than assembly due to simplicity and readability.
      You can download the Lite Version of HI-TECH C compiler for PIC10/12/16 MCU for free
    3. Chip programmer
      To program the chip use either WinPic800 or IC-Prog Prototype Programmer. For this tutorial, I'll be using WinPic800.
    Once all these are prepared, next step is to prepare MP LAB and HI-TECH C compiler work together.
    1. Install MP LAB and HI-TECH C compiler to your PC
    2. Open MP LAB
    3. Go to Projects menu and click on Select Language Toolsuite...
    4. Select HI-TECH Universal Tool Suite from the list
    5. Click on Browse button and set the path to picc.exe as below
    6. Click Ok button
    Now, we have setup the HI-TECH C compiler to MP LAB IDE successfully. Next step is to write the program. I'm sure most of you are interested in this step.
    First note that, we have connected the LED to First pin of PORT A (RA0).
    Save following 4 source files to disk in given names.
    main.c
    * Project		: Simple Tutorial
    * File			: main.c
    * Description	: Simple LED blink project
    * Author		: Neo
    * Copyright		: ROBOT.LK
    * Version	Date		Author					Change/Reason
    *	1.0		29/03/2010	NEO						Created
    #include <pic.h>
    #include "delay.h"
    main()
    	int current_status = 1; // Initialise to 1
    	// Configuring PORT A
    	ADCON1 = 0;	// Make all pins on PORTA as GPIO (Not ADC)
    	TRISA = 0;	// Set all 6 pins as outputs
    	PORTA = 0;	// Set all 6 pins to low at startup
    	while(1){
    		DelayBigMs(1000); // Wait 1 second
    		RA0 = current_status;
    		current_status = current_status ^ 1; // Alternate between 1 and 0
    As in comments of the code, we will set PORT A as an output port. Then we make all 6 pins to low at start up.
    Later on the while loop, we wait for 1 second and then switch on the LED. On the next iteration, we off the LED and this will repeat indefinitely. Alternating between 1 and 0 is done by a simple XOR operation. If you are not clear of this program, please ask me under same post.
    Always.h
    Common header file
    Designed by Shane Tolmie of www.microchipC.com corporation.  Freely distributable.
    Questions and comments to [email protected]
    Lots of Hi-Tech C FAQ and sample source code at www.microchipC.com.
    For Microchip PIC16Fx.
    Compiled with Hitech-C v7.85
    Usage: #include in all ".c" files in project along with "pic.h"
    //warning about #if statements: if any of the arguments are spelled wrong or
    //unrecognised by the compiler, it will not generate a warning, but not include code
    #ifndef ALWAYS_H
    #define ALWAYS_H
    Turning bits on/off according to mask
    use ~0 instead of 0xFF, etc, because this ensures machine independence
    if int changes from 16-bit to 32-bit
    Example C:
    x=0b001;
    bits_on(x,0b100)  //now x=0b101
    #define bits_on(var,mask) var |= mask
    #define bits_off(var,mask) var &= ~0 ^ mask
    //defines
    #define INPUT 1		//port directions, ie: TRISA0=INPUT;
    #define OUTPUT 0
    #define TRUE 1
    #define FALSE 0
    #define	HIGH 1
    #define	LOW 0
    #define	hi 1
    #define	lo 0
    #define b asm("nop")		//convenient point for breakpoint (debugging)
    #define l while(1)			//loop for ever (debugging)
    //see AM576.  If interrupt occurs just when gie gets set to zero, it won't be cleared
    #define	gie_on		GIE=1
    #define gie_off		while(GIE==1) GIE=0
    Reading an 8-bit byte in a 16-bit int
    With Hi-Tech C, this method is better than using pointers, as using pointers in
    different banks needs different #defines
    It is just as efficient - the optimizer picks out the correct
    byte.  Of course, >>7 requires 7 shifts.
    This method cannot be used to alter a hi/lo byte, this needs pointers (as below)
    Example C:
    unsigned int x;
    unsigned char y;
    x=0x1234;
    y=hibyte(x);  	  //now y=0x12 - works for variables in any bank 0 to 3
    y=lobyte(x);	    //now y=0x34
    lobyte(x)=0xaa;   //will not work :( - use pointers
    #define hibyte(x) (unsigned char)(x>>8)
    #define lobyte(x) (unsigned char)(x & 0xFF)
    given variable of any type (char, uchar, int, uint, long) it modifies
    	the unsigned char residing at that memory location
    	for ints, byte1 is msb, byte0 is lsb (least significant byte)
    	for longs	byte3 is msb, byte0 is lsb
    	ie: sample C code
    	unsigned int myint=0x4321;
    	long mylong=0x87654321;
    	//for myint 	byte1(myint)=0x43; (msb) and byte0(myint)=0x21; (lsb)
    	//for mylong	byte3(mylong)=0x87; (msb), byte2(mylong)=0x65;
    								byte2(mylong)=0x43; and byte0(mylong)=0x21; (lsb)
    	note:	to avoid fixup overflow errors add bankX if the target variable
    				resides in banks 1, 2 or 3
    #define byte0(x)		(unsigned char)(*(((unsigned char *)&x)+0))
    #define byte1(x)		(unsigned char)(*(((unsigned char *)&x)+1))
    #define byte2(x)		(unsigned char)(*(((unsigned char *)&x)+2))
    #define byte3(x)		(unsigned char)(*(((unsigned char *)&x)+3))
    #define lobyte_atbank0   byte0   //another way of saying it
    #define hibyte_atbank0   byte1
    #define byte0_atbank1(x)		(unsigned char)(*(((bank1 unsigned char *)&x)+0))
    #define byte1_atbank1(x)		(unsigned char)(*(((bank1 unsigned char *)&x)+1))
    #define byte2_atbank1(x)		(unsigned char)(*(((bank1 unsigned char *)&x)+2))
    #define byte3_atbank1(x)		(unsigned char)(*(((bank1 unsigned char *)&x)+3))
    #define lobyte_atbank1   byte0_atbank1  //another way of saying it
    #define hibyte_atbank1   byte1_atbank1
    #define byte0_atbank2(x)		(unsigned char)(*(((bank2 unsigned char *)&x)+0))
    #define byte1_atbank2(x)		(unsigned char)(*(((bank2 unsigned char *)&x)+1))
    #define byte2_atbank2(x)		(unsigned char)(*(((bank2 unsigned char *)&x)+2))
    #define byte3_atbank2(x)		(unsigned char)(*(((bank2 unsigned char *)&x)+3))
    #define byte0_atbank3(x)		(unsigned char)(*(((bank3 unsigned char *)&x)+0))
    #define byte1_atbank3(x)		(unsigned char)(*(((bank3 unsigned char *)&x)+1))
    #define byte2_atbank3(x)		(unsigned char)(*(((bank3 unsigned char *)&x)+2))
    #define byte3_atbank3(x)		(unsigned char)(*(((bank3 unsigned char *)&x)+3))
    	the int residing at that memory location
    	ie: sample C code
    	unsigned char array[4];
    	unsigned int test;
    	uint_atbyteaddr(&array[0])=0x4321;			//now array[0->3]={0x21,0x43,0,0};
    	uint_atbyteaddr(&array[0+2])=0x8765;		//now array[0->3]={0x21,0x43,0x65,0x87};
    	test=uint_atbyteaddr(&array[0+2])				//now test=0x8765
    	note: do NOT use &(array[0]+1) to reference the int stored at array[1] as it will
    				reference the int after array[0] in pointer arithmetic.  This will
    				result with the int at array[2].
    				Instead use &array[0+1] to reference the int at uchar array[1]
    #define	uint_atbyteaddr(x)					(unsigned int)(*(((unsigned int *)x)))
    #define	uint_atbank1byteaddr(x)			(unsigned int)(*(((bank1 unsigned int *)x)))
    #define	uint_atbank2byteaddr(x)			(unsigned int)(*(((bank2 unsigned int *)x)))
    #define	uint_atbank3byteaddr(x)			(unsigned int)(*(((bank3 unsigned int *)x)))
    #define THE_BEER_IS_PLENTIFUL_AND_THE_PARTY_SWINGING TRUE
    NOTE: it is not recommended that unions are used to reference hi/lo bytes or
    bits of a variable.  Use >>8 or &FF or pointers instead, as above.  It makes
    passing variables to a function difficult, as the function must be defined to
    accept variables of the same union.  Then, the function will no longer accept
    normally defined variables.
    these two structures allow access to 2 byte word, high and low bytes of variable
    declaration:	union wordtype x;
    usage:	x.word=0xABCD; x.byte.high=0xAB; x.byte.low=0xCD;
    				x.part.bit15=1; (msb), x.part.bit0=1; (lsb)
    declaration:	union chartype x;
    usage:	x.byte=0xAB;
    				x.part.bit7=1; (msb), x.part.bit0=1; (lsb)
    struct sixteen_bits
    	unsigned char bit0	:1;
    	unsigned char bit1	:1;
    	unsigned char bit2	:1;
    	unsigned char bit3	:1;
    	unsigned char bit4	:1;
    	unsigned char bit5	:1;
    	unsigned char bit6	:1;
    	unsigned char bit7	:1;
    	unsigned char bit8	:1;
    	unsigned char bit9	:1;
    	unsigned char bit10	:1;
    	unsigned char bit11	:1;
    	unsigned char bit12	:1;
    	unsigned char bit13	:1;
    	unsigned char bit14	:1;
    	unsigned char bit15	:1;
    struct eight_bits
    struct two_bytes
    	unsigned char low;
    	unsigned char high;
    union wordtype
    	unsigned int word;
    	struct two_bytes byte;
    	struct sixteen_bits part;
    union chartype
    	unsigned char byte;
    	struct eight_bits part;
    #endif
    Next there are two important files to attach to get the delay functionality (Delay.C and Delay.h).
    Delay.C
    high level delay routines - see delay.h for more info.
    Questions and comments to [email protected].
    PICuWEB - Program PIC micros with C. Site has FAQ and sample source code.
    www.microchipC.com.
    For Microchip 12C67x, 16C7x, 16F87x and Hi-Tech C
    #ifndef __DELAY_C
    #define __DELAY_C
    #include <pic.h>
    #include	"always.h"
    unsigned char delayus_variable;
    #include	"delay.h"
    void DelayBigUs(unsigned int cnt)
    	unsigned char	i;
    	i = (unsigned char)(cnt>>8);
    	while(i>=1)
    		i--;
    		DelayUs(253);
    		CLRWDT();
    	DelayUs((unsigned char)(cnt & 0xFF));
    void DelayMs(unsigned char cnt)
    	unsigned char	i;
    	do {
    		i = 4;
    		do {
    			DelayUs(250);
    			CLRWDT();
    		} while(--i);
    	} while(--cnt);
    //this copy is for the interrupt function
    void DelayMs_interrupt(unsigned char cnt)
    	unsigned char	i;
    	do {
    		i = 4;
    		do {
    			DelayUs(250);
    		} while(--i);
    	} while(--cnt);
    void DelayBigMs(unsigned int cnt)
    	unsigned char	i;
    	do {
    		i = 4;
    		do {
    			DelayUs(250);
    			CLRWDT();
    		} while(--i);
    	} while(--cnt);
    void DelayS(unsigned char cnt)
    	unsigned char i;
    	do {
    		i = 4;
    		do {
    			DelayMs(250);
    			CLRWDT();
    		} while(--i);
    	} while(--cnt);
    #endif
    Delay.h
    #define PIC_CLK 4000000 //4Mhz
    lowlevel delay routines
    Designed by Shane Tolmie for www.microchipC.com. Freely distributable.
    Example C:
    #include "delay.h"
    unsigned int timeout_int, timeout_char;
    DelayUs(40);  //do NOT do DelayUs(N) of N<5 @ 4Mhz or else it executes DelayUs(255) !!!!
    DelayUs(255); //max
    dly250n;      //delay 250ns
    dly1u;        //delay 1us
    timeout_char=timeout_char_us(1147);
    while(timeout_char-- && (RA1==0));  //wait up to 1147us for port RA1 to go high
    				    //  - this is the max timeout
    timeout_int=timeout_int_us(491512);
    while(timeout_int-- && (RA1==0));   //wait up to 491512us for port RA1 to go high
    #ifndef __DELAY_H
    #define __DELAY_H
    extern unsigned char delayus_variable;
    #if (PIC_CLK == 4000000)
    	#define dly125n please remove; for 32Mhz+ only
    	#define dly250n please remove; for 16Mhz+ only
    	#define dly500n please remove; for 8Mhz+ only
    	#define dly1u asm("nop")
    	#define dly2u dly1u;dly1u
    #elif (PIC_CLK == 8000000)
    	#define dly500n asm("nop")
    	#define dly1u dly500n;dly500n
    #elif ( (PIC_CLK == 16000000) || (PIC_CLK == 16257000) )
    	#define dly250n asm("nop")
    	#define dly500n dly250n;dly250n
    #elif (PIC_CLK == 20000000)
    	#define dly200n asm("nop")
    	#define dly400n dly250n;dly250n
    	#define dly2u dly400n;dly400n;dly400n;dly400n;dly400n
    #elif (PIC_CLK == 32000000)
    	#define dly125n asm("nop")
    	#define dly250n dly125n;dly125n
    #else
    	#error delay.h - please define pic_clk correctly
    #endif
    //delay routine
    #if PIC_CLK == 4000000
    	#define DelayDivisor 4
    	#define WaitFor1Us asm("nop")
    	#define Jumpback asm("goto $ - 2")
    #elif PIC_CLK == 8000000
    	#define DelayDivisor 2
    #elif ( (PIC_CLK == 16000000) || (PIC_CLK==16257000) )
    	#define DelayDivisor 1
    #elif PIC_CLK == 20000000
    	#define WaitFor1Us asm("nop"); asm("nop")
    	#define Jumpback asm("goto $ - 3")
    #elif PIC_CLK == 32000000
    	#define WaitFor1Us asm("nop"); asm("nop"); asm("nop"); asm("nop"); asm("nop")
    	#define Jumpback asm("goto $ - 6")
    #else
    #endif
    #define DelayUs(x) { \
    			delayus_variable=(unsigned char)(x/DelayDivisor); \
    			WaitFor1Us; } \
    			asm("decfsz _delayus_variable,f"); \
    			Jumpback;
    timeouts:
    C code for testing with ints:
    			unsigned int timeout;
    			timeout=4000;
    			PORT_DIRECTION=OUTPUT;
    			while(1)
    				PORT=1;
    				timeout=8000;
    				while(timeout-- >= 1);	//60ms @ 8Mhz, opt on, 72ms @ 8Mhz, opt off
    				PORT=0;
    Time taken:	optimisations on:		16cyc/number loop, 8us @ 8Mhz
    			optimisations off:		18cyc/number loop, 9us @ 8Mhz
    			with extra check ie:	&& (RB7==1), +3cyc/number loop, +1.5us @ 8Mhz
    C code for testing with chars:
    			similar to above
    Time taken:	optimisations on:		9cyc/number loop, 4.5us @ 8Mhz
    Formula:	rough timeout value = (<us desired>/<cycles per loop>) * (PIC_CLK/4.0)
    To use:		//for max  timeout of 1147us @ 8Mhz
    			#define LOOP_CYCLES_CHAR	9					//how many cycles per loop, optimizations on
    			#define timeout_char_us(x)	(unsigned char)((x/LOOP_CYCLES_CHAR)*(PIC_CLK/4.0))
    			unsigned char timeout;
    			timeout=timeout_char_us(1147);						//max timeout allowed @ 8Mhz, 573us @ 16Mhz
    			while((timeout-- >= 1) && (<extra condition>));	//wait
    To use:		//for max 491512us, half sec timeout @ 8Mhz
    			#define LOOP_CYCLES_INT		16					//how many cycles per loop, optimizations on
    			#define timeout_int_us(x)	(unsigned int)((x+/LOOP_CYCLES_INT)*(PIC_CLK/4.0))
    			timeout=timeout_int_us(491512);						//max timeout allowed @ 8Mhz
    #define timeout_char_us(x)	(long)(((x)/LOOP_CYCLES_CHAR)*(PIC_CLK/1000000/4))
    #define timeout_int_us(x)	(long)(((x)/LOOP_CYCLES_INT)*(PIC_CLK/1000000/4))
    //if lo byte is zero, faster initialization by 1 instrucion
    #define timeout_int_lobyte_zero_us(x)	(long)(((x)/LOOP_CYCLES_INT)*(PIC_CLK/4.0)&0xFF00)
    //function prototypes
    void DelayBigUs(unsigned int cnt);
    void DelayMs(unsigned char cnt);
    void DelayMs_interrupt(unsigned char cnt);
    void DelayBigMs(unsigned int cnt);
    void DelayS(unsigned char cnt);
    #endif
    Save these two files for later use. Note that, on Delay.h, we have to set the oscillator value. In our case, we have set it to a 4MHz.
    In this step, we are going to create a project using MP LAB.
    1. Go to Project menu and click on Project Wizard
    In the next step you need to select the main.c and the two delay files as listed above.
    Click on Finish.
    On MP LAB, you will see a window named as MyFirstProject.mcw as below.
    If you don't have it yet, you can get it by going to View menu and clicking on Project. You will see all 3 files are attached to the project now.
    Now, we need to compile the project.
    Go to Project menu and click on Build (Alternatively you can press Ctrl+F10) to build the project. You will get an output witndow as below.
    Check whether you have a file called MyFirstProject.hex in the project folder. This is the output file that is required to burn to Flash memory of 16F877 Microcontroller.
    We will be using WinPic800 to do this.
    1. Insert the PIC16F877 microcontroller to the ZIF socket of the programmer in the right direction
    2. Plug serial cabel from PC to Programmer board
    3. Install the program and run WinPic800 executable
    4. Click on Settings menu and click on Hardware
    5. Select JDM programmer (As above)
    6. Now select the COM port. For my system I have selected COM1.
    7. Click on Apply edits
    8. Click on Settings button on Toolbar and make the settings as in the following screenshot (if different).
    Now we are going to program the Hex file to PC16F877 Microcontroller
    1. Select PIC 16F and 16F877A on the controls at top-right corner as below.
    2. Now click on Erase All button to clear the Flash memory of the microcontroller (This step is not essential). Notice the LED of the programmer which should blink while programming the flash memory.
    3. Now, go to File menu and click on Open
    4. Select the Hex file that was generated before
    5. Now click on Program All button
    6. After the process is completed, click on Verify All to make sure data is written successfully
    7. Done!
    We are going to run the code that we have just flashed on our custom board now.
    1. Place the microcontroller to the custom board (or breadboard)
    2. Now, switch on the board
    3. You must see the LED is blinking on custom board
This is the end of the my microcontroller tutorial. Let me know your ideas, comments, etc... and if you have questions, please ask under this post.
Re: How to start with Microcontrollers
Post by Rksk » Fri Apr 16, 2010 12:10 pm
Can anyone give the compiled hex file for this project.
PLS help me.
Post by Neo » Fri Apr 16, 2010 1:01 pm
I have that, but I will not give you :D If I give you, you will not learn.
Try to follow the steps and compile it yourself. If you have any problem in compiling the code (with given tools), just let me know.
Post by Neo » Sat Apr 17, 2010 2:25 am
First, kind request to make to you in public this time. I made it clear few times to you.
Do not add any link which either has no value or may confuse our members.
I got about 20+ thanking PMs on this article from members who made this and got it successfully working. We always encourage such people.
This article is not about putting a hex file to Proteus to simulate. I think you are clear on my point.
As you have build up some reputation with me on J2ME things, find the hex file attached here. But do not expect me to do things for you in future. We just give tips and guides. You have to experiment yourself ;)
test.zip
(436 Bytes) Downloaded 1227 times
Post by Rksk » Sat Apr 17, 2010 9:22 am
I agree with neo.
thankz.
Post by Rksk » Sun Apr 18, 2010 3:17 pm
I found MPLAB IDE v6.40 from a friend.
will HI-TECH C compiler for PIC10/12/16 MCU new version suitable for MPLAB IDE v6.40 :?:
Post by Neo » Sun Apr 18, 2010 5:00 pm
Yes. It should work. Give it a try.
Also, why don't you try to write directly in assembly?
If you write in assembly, you don't need HI-TECH compiler as MPLAB provides a free assembly compiler.
I suggest you to write in assembly because it is so much fun + you will understand the behaviour of the micro 100%.
If your applications is too complicated, then you can write in C and write most critical codes in Assembly. So in a large scale application, you will typically see both C and assembly codes in a mixture.
However you can decide on this.
Post by Rksk » Sun Apr 18, 2010 5:06 pm
I don't know assembly. i think C is easy.
Post by Neo » Sun Apr 18, 2010 5:11 pm
Cool 8-)
As I said it is all depending on your personal satisfaction. Go ahead.
Enigma
Post by Enigma » Wed Jan 19, 2011 10:48 pm
hi Neo
First of all very nice tutorial. I'm completely new to this. So I have some questions.
1.I do have the 16F877A microcontorller. But where can I buy WinPic800 or IC-Prog Prototype Programmer ?? Are they available in Sri Lanka ?
2. Can you recommend me a nice book for this ?
