USB example for PIC18F4550. Plug your PIC18F4550 into your PC using a USB cable. A virtual RS232 COM port is created, allowing your application to print RS232 messages into HyperTerminal. Allows porting of legacy code that used RS232 comms.
This project is a modified form of the CDC (Communications Class Driver) available from http://www.microchip.com. The http://www.htsoft.com forum has some discussion on this code.
Note: ensure that you read "readme (including install notes).txt" after download.
Schematics: this code runs on the PICDEM-FS board from Microchip. To make your own schematic, place a PIC18F4550 on a breadboard, ensure that you are using a 20Mhz crystal, place a 470nF capacitor on port Vusb, and hook the USB directly to the chip. It should start to work straight away. Download the PICDEM-FS datasheet for the exact schematic to use with this code.
Result: start up HyperTerminal or putty, find the new COMx port that has been enumerated. Set it to 115200,N,8,1. The actual COM port speed doesn't matter, as its a virtual comm port. You will see "[alive]" being continuously generated on virtual com port X over USB. You can find the exact number of the virtual COM port by going into "Control Panel", then "System", then selecting the "Hardware" then "Device Manager", there will be a new COM port under "Ports (COM & LPT). You can change the number of the virtual comm port by going into properties, and selecting the new COM port.
Download PIC18F4550 USB serial port example v1.02 (540KB)
Download PIC18F4550 USB serial port example v1.10 (540KB)
USB Serial port on PIC18F4550
