How to connect IR Remote Controller for microcontroller
TRONICLK
Contact:
Post by TRONICLK » Sat Apr 06, 2013 8:26 pm
If you bought IR Receiver Module Wireless Remote Control Kit for Arduino from TRONIC.LK, here is a quick guide on integrating that to Arduino or any other microcontroller based board.
Connection diagram.
Key codes for this remote controller:
#define IR_POWER	0xFFA25D
#define IR_MODE		0xFF629D
#define IR_MUTE		0xFFE21D
#define IR_PLAY		0xFF22DD
#define IR_BACKWD	0xFF02FD
#define IR_FORWD	0xFFC23D
#define IR_EQ		0xFFE01F
#define IR_MINUS	0xFFA857
#define IR_PLUS		0xFF906F
#define IR_LOOP		0xFF9867
#define IR_USD		0xFFB04F
#define IR_0		0xFF6897
#define IR_1		0xFF30CF
#define IR_2		0xFF18E7
#define IR_3		0xFF7A85
#define IR_4		0xFF10EF
#define IR_5		0xFF38C7
#define IR_6		0xFF5AA5
#define IR_7		0xFF42BD
#define IR_8		0xFF4AB5
#define IR_9		0xFF52AD
#define IR_HOLD		0xFFFFFFFF
Sample code:
  SparkFun Electronics 2010
  Playing with IR remote control
  IR Receiver TSOP382: Supply voltage of 2.5V to 5.5V
  With the curved front facing you, pin 1 is on the left.
  Attach
    Pin 1: To pin 2 on Arduino
    Pin 2: GND
    Pin 3: 5V
  This is based on pmalmsten's code found on the Arduino forum from 2007:
  http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1176098434/0
  This code works with super cheapo remotes. If you want to look at the individual timing
  of the bits, use this code:
  http://www.arduino.cc/playground/Code/InfraredReceivers
  This code clips a lot of the incoming IR blips, but what is left is identifiable as key codes.
int irPin = 2; //Sensor pin 1 wired to Arduino's pin 2
int statLED = 13; //Toggle the status LED every time Power is pressed
int start_bit = 2200; //Start bit threshold (Microseconds)
int bin_1 = 1000; //Binary 1 threshold (Microseconds)
int bin_0 = 400; //Binary 0 threshold (Microseconds)
void setup() {
  pinMode(statLED, OUTPUT);
  digitalWrite(statLED, LOW);
  pinMode(irPin, INPUT);
  Serial.begin(9600);
  Serial.println("Waiting: ");
void loop() {
  int key = getIRKey();		    //Fetch the key
  if(key != 0) //Ignore keys that are zero
    Serial.print("Key Recieved: ");
    switch(key)
      case 144: Serial.print("CH Up"); break;
      case 145: Serial.print("CH Down"); break;
      case 146: Serial.print("VOL Right"); break;
      case 147: Serial.print("VOL Left"); break;
      case 148: Serial.print("Mute"); break;
      case 165: Serial.print("AV/TV"); break;
      case 149:
        Serial.print("Power");
        if(digitalRead(statLED) != 1) //This toggles the statLED every time power button is hit
          digitalWrite(statLED, HIGH);
        else
        break;
      default: Serial.print(key);
    Serial.println();
int getIRKey() {
  int data[12];
  int i;
  while(pulseIn(irPin, LOW) < start_bit); //Wait for a start bit
  for(i = 0 ; i < 11 ; i++)
    data[i] = pulseIn(irPin, LOW); //Start measuring bits, I only want low pulses
  for(i = 0 ; i < 11 ; i++) //Parse them
    if(data[i] > bin_1) //is it a 1?
      data[i] = 1;
    else if(data[i] > bin_0) //is it a 0?
      data[i] = 0;
    else
      return -1; //Flag the data as invalid; I don't know what it is! Return -1 on invalid data
  int result = 0;
  for(i = 0 ; i < 11 ; i++) //Convert data bits to integer
    if(data[i] == 1) result |= (1<<i);
  return result; //Return key number
Datasheet:
TSOP18.pdf
(133.26 KiB) Downloaded 977 times
Another nice example: http://www.righto.com/2009/08/multi-pro ... brary.html
Return to “Arduino”
