You mean configuration.
1. Since you have a transformer isolation, buck converter is oky.
You have to decide the operating switching frequency, then you have to decide the inductor value, then
maximum current through the inductor, then it should provide some headroom against core saturation.
You have to do stress checking against those items.
If you only willing to down stepping then there's no need of buck-boost converter topology.
And when selecting the switching frequency, high frequency is fine for many reasons.
1. Fast response time.
2. Low output capacitor value.
3. small core size of the inductor.
But the disadvantages are.
1. High hysteresis loss.
2. High frequency switching electronics come with a price.
3. high frequency componment will generate EMI (electro-magnetic interference and sometimes lead to
hum in audio system).
1) what is the best current metering method for this config? i need a readout accurate to 1mA- eg: 853mA (display consists of three 7-segments) for currents below 1A, and 100mA (eg- 09.2A) for currents above 1A (max current is ~10A).
All the configurations that I have reviewed , it they have use a serious 1ohm 5W like resistor to current sensing.
So it's accuracy is depending on it's tollorance value. High accurate resistor could be made using a FET, see the
configuration , FET as a variable resistor,so you could also calibrate it as you need. But I never seen a configuration
which uses FET as a variable resistor before. But this could be easily implemented.
high precision resistors were build by laser trimming. But I don't think even Aptinx like company in SL have process
that technology. I don't know how much it is fesable for you to , I mean for accurate as 7 digits.
As a person who learn electronics , I could suggest these alternatives.
1. Current transformer method.
2. Current mirror method. [you could configure current mirror to mirror 0.001 part of the original current flow].
3. If you need to compare currents , study the mechanism used in the RCCB switch, same principle could also
be used, for a example a simple troid with three coils, one is feedback, primary and secondary. If say primary
coil runs 1A, and secondary coil runs 0.9mA and we have 1:1000 ratio , then there is a 10% unbalance that could
be identified by the feedback coil. I think you get what I'm suggesting.
2) <I'm new to PIC programming.> I'm thinking of using the F88's comparators to do the regulation job (set Vref= value proportional to required output voltage and then increase/ decrease duty cycle on occurrence of interrupt as relevant),
what you asking here is not clear. Are you asking the internal mechanism of it? if so there's a DA conversion, simply
a
ladder circuit. So did you understand what Vref used to and
how it generates voltage to be compared by Vref and digital bit value in a register. Simply if you know how that unit
works , then programming it is not a big deal.
