Page 2 of 2
Re: How to scrap text from internet in VB
Posted: Wed Sep 28, 2011 11:53 pm
How use POST method?
Dim req As XMLHTTP
Set req = New XMLHTTP
req.open "POST", "https://robot.lk/viewtopic.php", False
req.setRequestHeader "Content-Type", "application/x-www-form-urlencoded"
req.send "f=9&p=8633"
Text1.Text = req.responseText
Posted: Thu Sep 29, 2011 12:42 am
by Rksk
Thank you.
Re: How to scrap text from internet in VB6
Posted: Sat Oct 08, 2011 12:01 pm
by Rksk
Neo wrote:
Dim req As XMLHTTP
req.open "GET", "https://robot.lk/index.php", False
req.send ""
This works fine with remote hosts. But doesn't work with localHost. how do I resolve?
Thankz.
Posted: Sun Oct 09, 2011 5:36 pm
Should work. Can you provide more details on the command line you use and the web server you are running.
If you are running WAMP,
http://localhost/myfile.php should work. Be sure to use http:// prefix.
Posted: Mon Oct 10, 2011 8:34 am
by Rksk
- vb errror2.jpg (94.97 KiB) Viewed 9534 times
Posted: Mon Oct 10, 2011 3:11 pm
Worked on the first run!
I can't guess anything without seeing your code.
- lh.PNG (22.12 KiB) Viewed 9530 times
Posted: Wed Oct 12, 2011 12:26 pm
by Rksk
Yes, I found the error.
The computer must be connected to the internet to call localhost too.
It doesn't work, Without an internet connection.
I tried with Xampp. I don't know where is the problem.
Posted: Wed Oct 12, 2011 12:45 pm
Try
WAMP. It might work without an internet connection.
