How To Validate Numbers in TextBox
Posted: Wed Mar 17, 2010 11:19 pm
This program will not allow users to input non-numeric characters. FYI, KeyAscii code for numbers is between 48-57.
The problem is users cannot erase or add point to the number he input. Let's change the program.
The problem still remain. How if the user add plus sign more than one? It can't be handled by the program above. I will update it later.
Private Sub Text1_KeyPress(KeyAscii As Integer)
If KeyAscii < 48 Or KeyAscii > 57 Then
KeyAscii = 0
Beep
End If
End Sub
Select Case KeyAscii
Case Asc(0) To Asc(9)
Case Asc("-"), Asc("+"), Asc("."), Asc(",")
Case 8, 13 '8 for backspace and 13 for enter
Case Else
KeyAscii = 0
Beep
End Select
End Sub
