TRONIC.LK Item List 801-900
Posted: Mon Mar 11, 2019 3:53 am
by TRONICLK
9V 1A SMPS Power Adapter
12V 2A SMPS Power Adapter
12V 2A SMPS Small Power Supply Metal Casing
12V 2A SMPS Large Power Supply Metal Casing
12V 3A SMPS Large Power Supply Metal Casing
24V 5A SMPS Power Supply Metal Casing Large
TV Power Module Repair Board 14-21" Mini 3-wire HM619
DVD Power Module Repair Board Small
Samsung Phone Charger 5V 2A (Original)
Travel Charger Normal 5V 700mA for Samsung
Travel Charger for Nokia Phones 5V 800mA Grade B
Travel Charger for Samsung Phones 5V 800mA 6500 Grade C
Travel Charger for Nokia Phones 5V 800mA 6101 Grade C
Earphone Hands-free for Samsung Phones Normal
Adjustable 30VDC 5A Professional Power Supply
Adjustable 30VDC 3A Professional Power Supply
8.5mm Pitch 2-Pin 2-Way Screw Barrier Terminal Block
8.5mm Pitch 3-Pin 3-Way Screw Barrier Terminal Block
8.5mm Pitch 4-Pin 4-Way Screw Barrier Terminal Block
TB-1506 600V 15A 6-Positions Barrier Strip Terminal Block
RV1.25-6 Insulated Ring Terminal Connector AWG 22-16
Battery Lug Blade Female Connector Brass 4.8x0.8mm
Fork Crimp Insulated Terminal Block Connector Uclip SV1.25-4 22-16AWG
Battery Lug Blade Female Spade Connector FDD2-250 16-14 AWG
5.08mm Pitch 2-Pin 2-way Screw Terminal Block PCB Mount
5.08mm Pitch 3-Pin 3-way Screw Terminal Block PCB Mount
2-Junction Join Wire Terminal Connector
3-Junction Join Wire Terminal Connector
12-pin Single row male angle headers 2.54mm
40-pin Single row male headers 2.54mm
40-pin Single row female headers 2.54mm
40-pin Single row male angle headers 2.54mm
40-pin Single row female angle headers 2.54mm
40-pin Double row male headers 2.54mm
40-pin Double row female angle headers 2.54mm
40-pin Double row male angle headers 2.54mm
8-pin Normal IC Base 2.54mm
14-pin Normal IC Base 2.54mm
16-pin Normal IC Base 2.54mm
18-pin Normal IC Base 2.54mm
20-pin Normal IC Base 2.54mm
28-pin Normal IC Base 2.5mm
40-pin Normal IC Base 2.54mm
14-pin ZIF Socket
28-pin ZIF Socket
40-pin ZIF Socket Universal
Jumper clip 2.54mm
DC Jack Barrel Connector Female
DC Jack Barrel Plug Male
2.1mm Female 3-Pin Barrel-Type PCB Panel Mount Connector
5.5x2.1mm Female 3-Pin Barrel Type Panel Mount DC Power Supply Jack Socket Connector
RJ45 Socket PCB Mount 5921 8P
RJ45 Socket PCB Mount 5621 8P with LED Indicators
DB9 Female Right Angle PCB Mount Connector
Mini USB Socket Female 5pin SMD PCB Mount
D-SUB DB15 Female Wire Solder Type Connector
DB25 Female Connector with Housing
DB25 Male Connector with Housing
Micro SIM Card Socket Push-Push Type SMD PCB Mount
USB Socket Female Type A Straight
USB Socket Female Type A Right Angle PCB Mount
USB Socket Male Type A Plug Metal Housing Shell
MicroSD Card Socket Push-Push Type SMD PCB Mount
SD Card Socket SMD PCB Mount
Right angle tactile push button 6 x 6 x 6mm
Right angle tactile push button 6 x 6 x 7mm
Right angle tactile push button 6 x 6 x 9mm
Right angle tactile push button 6 x 6 x 14mm
Tactile push button 6 x 6 x 6mm
Tactile push button 6 x 6 x 7mm
Tactile push button 6 x 6 x 9mm
Tactile push button 6 x 6 x 14.5mm
Tactile Push Button Switch Momentary 12 x 12 x 7.3mm
Green Colour Cap Knob for Tact Switch 12 x 12 x 7.3mm
Red Colour Cap Knob for Tact Switch 12 x 12 x 7.3mm
White Colour Cap Knob for Tact Switch 12 x 12 x 7.3mm
Black Colour Cap Knob for Tact Switch 12 x 12 x 7.3mm
Blue Colour Cap Knob for Tact Switch 12 x 12 x 7.3mm
Tactile Push Button Switch 4 x 4 x 1.5mm
Tactile Push Button Switch 3 x 6 x 2.5mm
Stainless Steel Metal Push Button 16mm
RS25 Rotary Potentiometer Switch Blade 4x3 Speed Gear
SPST Red Light Round Rocker Switch 3-Pin 6A 250V
SPDT Toggle Switch 6-Pin 250VAC 3A
Rotary Encoder Push Button Switch 12mm
1P 1-Position DIP-Switch 2.54mm Pitch 2 Row 2 Pin
2P 2-Position DIP-Switch 2.54mm Pitch 2 Row 4 Pin
3P 3-Position DIP Switch 2.54mm Pitch 2 Row 3Pin
4P 4-Position DIP Switch 2.54mm Pitch 2 Row 8 Pin
5P 5-Position DIP Switch 2.54mm Pitch 2 Row 10 Pin
8P 8-Position DIP Switch 2.54mm Pitch 2 Row 16 Pin
Mini Momentary Push Button Switch Red
SPST Rectangular Rocker Switch Black 2-Pin
Push On/Off Switch Round Plastic Black Long PBS11
Push On/Off Switch Square Plastic Red
Micro Limit Switch with 15mm Roller Lever 16A 250VAC
Micro Limit Switch with 15mm Lever 16A 250VAC
Micro Limit Switch with 20mm Roller Lever 5A 250VAC
Micro Limit Switch with 25mm Lever 16A 250VAC
Micro Limit Switch with 30mm Roller Lever 16A 250VAC
