Page 1 of 2
Execution Problem
Posted: Mon Apr 26, 2010 6:20 pm
by leesandy44
can anyone help me to write a c program to swap two numbers? i wrote the following program. at the compilation its not making any errors, but at the execution its not giving the correct output. actually its not swapping the numbers. Please help me to find the error.
#include<conio.h>
void main()
int a; int b; int temp;
a=0, b=0;
clrscr();
printf("Input two numbers\n');
scanf("%d%d",&a,&b);
temp=a;
b=a;
b=temp;
printf("%d%d",a,b,);
getch();
Re: Execution Problem
Posted: Mon Apr 26, 2010 7:23 pm
The corrected program can be found below.
#include<conio.h>
void main()
a=0, b=0;
clrscr();
temp=a;
a=b;
b=temp;
getch();
Note a=b;, you used b=a so it is a simple bug.
When you define variables in a single line you could use as below (you may also set initial values).
However the swap can be written more meaningfully using pointers as below.
#include <stdio.h>
void swap(int *a, int *b){
int temp;
temp = *a;
*a = *b;
*b = temp;
void main()
int a = 0, b = 0, temp;
clrscr();
scanf("%d%d", &a, &b);
swap( &a, &b);
getch();
Posted: Thu Apr 29, 2010 5:48 pm
by leesandy44
that means there's a special keyword for swapping???
Posted: Thu Apr 29, 2010 6:58 pm
No. Not a keyword.
We have written a function void swap(int *a, int *b) for this.
Posted: Thu Apr 29, 2010 7:41 pm
by leesandy44
okay. thank you Neo. still i haven't learn much functions. thank you so much for the help.
Posted: Thu Apr 29, 2010 8:00 pm
You are always welcome. This is the purpose of ROBOT.LK.
If you have any problem, do not hesitate to submit.
Posted: Fri Apr 30, 2010 6:29 pm
by leesandy44
Neo I wrote the following program. But it has a compilation error. It says "Misplaced else". could you please help me to correct this???
#include<conio.h>
void main()
int m;
m=0;
clrscr();
printf("input module mark");
scanf("%d"\n",&m);
if(m>=50);
printf("you are pass");
else
printf("you are fail");
getch();
Posted: Fri Apr 30, 2010 6:56 pm
Remove the semicolon in red colour. This will tell the compiler that if command ends with semicolon so the else is not valid.
#include<conio.h>
void main()
int m;
m=0;
clrscr();
scanf("%d"\n",&m);
if(m>=50);
else
getch();
Posted: Sun May 02, 2010 1:45 pm
by leesandy44
thank you Neo. Now its working.
Posted: Wed May 05, 2010 11:31 am
by leesandy44
please help me to find the error of the following program...
#include<conio.h>
void main()
int i,j;
for(j=1;j<10;j++);
if(j%3==0)
continue
printf("j=%d",j);
getch();
i wanna know more about continue keyword. please send me some sites or some details..
