Destructor call problem.
Posted: Fri Apr 16, 2010 6:46 pm
hi,
I have written the following code.
during debugging above code, i have found that
class test o1-- temp=1 as object is created.
class test o2=f(o1) temp=0xff as destructor is called two times.
I do not understand, why destructor is called two times.
kindly tell me, why this program behaves like this, according to my knowledge, output should be
during
class test o2=f(o1) temp=0;
kindly tell me why this difference comes.
Thanks & Regards
class test
{ public:
static unsigned char temp;
test()
{ temp++;
~test()
{ temp--;
test f(test t)
{ return t;
unsigned char test::temp=0;
int main()
{ class test o1;
class test o2=f(o1);
during
Thanks & Regards
