How to use .htaccess/.htpasswd Password Protection with PHP
Posted: Sun Nov 29, 2009 5:20 am
Setting up password protection
The best way to secure content on your website is to use .htaccess/.htpasswd protection. This will password protect any directory and all directories below. You will need to create a .htaccess file which you put in the directory you want to protect. You will also need to create a .htpasswd file which you will put out of reach (see tip on Securing Your Package). The .htaccess file should contain the following:
Where username is the name of the user specified in the .htpasswd file.
You can also make that last line
to accept any user specified in the .htpasswd file.
You can also limit the password protection. For example put the .htaccess code inside these tags
htaccess protection code goes here
to limit the password protection to just the file "file.ext".
The .htpasswd file should genrally be put at your ftp root (above the public directory). It is in the form:
The best way to create these files is using notepad (for example create htaccess.txt in notepad), then upload, then rename on the server (.htaccess).
You can encrypt the password using the form in B&T's Tool Box (on this page) or use your own script (also available on this page).
More information can be found on this technique in the Apache documentation here.
Encrypt your password for .htpasswd
Want your own script that you can use to make the encrypted password lines for your .htpasswd file? Use this one.
Auto Password Change and Email Notification
This script will change your .htpasswd password to a new random password (with encryption) and send an email to notify you of the change. You can run this script automatically using cron at what ever interval you like, or run it manually.
Auto generate .htpasswd file
This php script reads a MySQL database, encrypts the passwords and writes an htpasswd file. Using this script you can maintain a database of users and generate an .htpasswd file from the database.
Passing user authentication information to PHP
The best way to protect your directory is with htaccess/htpasswd protection. But you may also want to pass the user information to your php scripts so you can do custom processing based on who logged in. You can retrieve the current authenticated user with one php line. Put this in the target script in the protected directory (used in the script after authentication).
AuthUserFile /full_unix_path_to_your_file/.htpasswd
AuthName "Any Name You Want"
AuthType Basic
require user username You can also make that last line
require valid-user You can also limit the password protection. For example put the .htaccess code inside these tags
<files file.ext>Code: Select all
</files>The .htpasswd file should genrally be put at your ftp root (above the public directory). It is in the form:
user:encrypted password You can encrypt the password using the form in B&T's Tool Box (on this page) or use your own script (also available on this page).
<?php
if (!empty($_POST[password]) AND !empty($_POST[user])) {
$user = $_POST[user];
$password = $_POST[password];
$encryptedPassword = crypt($password);
$script = $_SERVER['SCRIPT_NAME'];
echo "<html><head><title>Password Encryption</title></head><body>
<form method=post action='$script'>
<font size=5><b>.htpasswd File Password Encryption</b></font>
<br><br>Enter Username<br>
<input name=user value='$user' size=20>
<br><br>Enter Password<br>
<input name=password value='$password' size=20>
<br><br><input type=submit name=submit value='Encrypt Now'>
if (!empty($user) AND !empty($encryptedPassword)) {
echo "<br><br>.htpasswd File Code<br>$user:$encryptedPassword";
echo "</form></body></html>";
<?php
$filename = "/XXXXXX/.htpasswd"; // the location of your .htpasswd file
$username = "XXXXXXX"; // the username specified in the .htaccess file
$length = "10"; // length of the password
$emailaddress = "[email protected]"; // email address
// change nothing below this line
// generate password
$spec_charset = array("!","@","#","$","%","^","&","*","_","+"."?","=");
$chars = array();
unset($pass);
for ($i = 1; $i <= $length; $i++) {
for ($i = 48; $i <= 57; $i++) $chars[] = chr($i); // numbers
for ($i = 65; $i <= 90; $i++) $chars[] = chr($i); // upper
for ($i = 97; $i <= 122; $i++) $chars[] = chr($i); // lower
foreach ($spec_charset as $i) $chars[] = $i; // special
for ($i = 1; $i <= $length; $i++) $pass .= $chars[rand(0,count($chars)-1)];
// build & write .htpasswd file
$encrypted = crypt($pass);
$output = "$username:$encrypted\n";
if (file_put_contents($filename,$output))
$message = "Your password has been changed to $pass";
else
$message = "There was an error creating your new password";
// send notification
mail($emailaddress,"Password Notification",$message,"From: Website <>");
<?php
$filename = "your htpasswd file path goes here"; // your htpasswd file name - complete unix path - or relative to this script
$host="host"; // database host address
$dbuser="user"; // database user name
$dbpswd="password"; // database password
$mysqldb="db_name"; // name of database
$table="passwd_table"; // name of table
// modify the above lines for your environment
mysql_connect("$host", "$dbuser", "$dbpswd");
mysql_select_db ("$mysqldb");
$query = mysql_query("SELECT * FROM $table");
while ($row = mysql_fetch_array($query)) {
$user = $row['user'];
$pass = $row['password'];
$record .= "$user:$encrypted\r\n";
file_put_contents($filename,$record);
<?php
$user = $_SERVER['REMOTE_USER'];
