Get the id of AUTO_INCREMENT field after INSERT using php
Posted: Fri Jul 15, 2011 6:11 pm
If you insert a new value to a MySQL database, and the id is an AUTO_INCREMENT field, this simple function will obtain the id for you without having to do a new query on the database. This is the easiest way to get the id from a newly added row using a MySQL insert query without having to do a second query.
<?php
// Do your insert query...
mysql_query("INSERT etc...");
// This finds the id of the row once it has been added...
$id = mysql_insert_id();
// Display it...
echo $id;
