php Header tips
Posted: Wed Mar 10, 2010 11:06 pm
- 301 moved permanently
- 302 moved temporarily
- 404 page not found
- Service not available
- CSS
- Javascript
- Images(JPEG,BMP,PNG)
- Force browsers not to cache pages
- Download dialog
- Authentication
301 moved permanently (redirect)
<?php
header('HTTP/1.1 301 Moved Permanently');
header('Location: http://www.example.com');
die();
302 moved temporarily(redirect)
<?php
die();
404 Page Not Found
<?php
header('HTTP/1.1 404 Not Found');
Service not avaliable
<?php
header('HTTP/1.1 503 Service Temporarily Unavailable');
header('Status: 503 Service Temporarily Unavailable');
header('Retry-After: 60');
CSS
<?php
header('Content-Type: text/css');
JavaScript header
<?php
header('Content-Type: application/javascript');
Images
For JPEG(jpg):
<?php
header('Content-Type: image/jpeg');
<?php
header('Content-Type: image/png');
<?php
header('Content-Type: image/bmp');
PDF (output pdf with php)
<?php
header('Content-Type: application/pdf');
echo file_get_contents('filename.pdf');
Cache (force browsers not to cache files)
<?php
header('Expires: Sat, 26 Jul 1997 05:00:00 GMT');
header('Cache-Control: no-store, no-cache, must-revalidate');
header('Cache-Control: pre-check=0, post-check=0, max-age=0');
header ('Pragma: no-cache');
Download dialog
<?php
header('Content-Disposition: attachment; filename=' . urlencode($f));
header('Content-Type: application/force-download');
header('Content-Type: application/octet-stream');
header('Content-Type: application/download');
header('Content-Description: File Transfer');
header('Content-Length: ' . filesize($f));
echo file_get_contents($f);
Authentication
(force the browser to pop up a Username/Password input window) - only available when PHP is running as an Apache module:
<?php
if (!isset($_SERVER['PHP_AUTH_USER'])) {
header('WWW-Authenticate: Basic realm="The Realm"');
header('HTTP/1.0 401 Unauthorized');
echo 'If cancel is pressed this text shows';
die();
} else {
//always escape your data//
$user='user';
$pass='pass';
if($_SERVER['PHP_AUTH_USER']==$user && $_SERVER['PHP_AUTH_PW']==$pass){
echo 'Authorized';
