How to keep track on returning visitors
Posted: Sat Feb 06, 2010 3:17 am
The easiest way to do this is by using cookies. But if the cookies are disabled by the browser, this won't work. A good solution is to keep track on the IP address and increment every 24-hours when a visitor browse the site. An example code to do this is given below.
CREATE TABLE IF NOT EXISTS `table` (
  `ip` text NOT NULL,
  `online` text NOT NULL
  `hits` text NOT NULL
) ENGINE=MyISAM DEFAULT CHARSET=latin1
// MySQL Connection
$connect = mysql_connect( 'localhost', 'username', 'password' ) or die(mysql_error());
mysql_select_db( 'database' );
$ip=$_SERVER['REMOTE_ADDR'];
$timestamp = time();
// checks if IP is in database
$getStats2 = mysql_query("SELECT * FROM `table` WHERE `ip`='$ip'") or die(mysql_error());
if( mysql_num_rows( $getStats2 ) == 0 )
      $select2 = mysql_query("INSERT INTO `table` (`ip`, `online`, `hits`) VALUES ('$ip','$timestamp','1')") or die(mysql_error());
else {
      // checks to see if last hit was before or after 24 hour mark.
      $diff = time() - 86400;
      $counthits = mysql_query("SELECT * FROM `table` WHERE `online` > '$diff' && ip='$ip'") or die(mysql_error());
      if (mysql_num_rows($counthits)==0){
            // unique hit
            while ($t=mysql_fetch_array($counthits)){
                  $hits=$t['hits'];
            //checks if there is 5 hits yet...
            if ($hits=="5"){
                  // do message!
            else {
                  $select2 = mysql_query("UPDATE `table` SET `online` = '$timestamp', `hits`=`hits`+1 WHERE `ip` = '$ip'");
      else {
            //not unique, does nothing...
