How to keep value received through GET method?
Posted: Sun Dec 02, 2012 5:26 pm
by Ranura
I want to keep the value "$aut_id" which is received through GET method.
It is destroyed (as usual) when I click the submit button.
Insert query needs "$aut_id" value after the clicking of submit button.
How can I achieve this?
Following is my code
<?php
	mysql_connect("localhost", "root", "123") or die (mysql_error ());
	mysql_select_db("popup_comment_box") or die(mysql_error());
	$name=$_POST['name'];
	$comment=$_POST['comment'];
	$submit=$_POST['submit'];
	$aut_id=$_GET['aut_id'];
	if($submit){
		if($name&&$comment){
			$query = "INSERT INTO tbl_comments
			(name, comment, timestamp, aut_id)
			SELECT '$name', '$comment', NOW(), aut_id
			FROM tbl_automobile
			WHERE aut_id = '$aut_id' LIMIT 1";
			mysql_query($query)  or die(mysql_error());
			echo "Your comment is successfully posted"."<br />";
		}else{
			echo "Please fill out all fields"."<br />";
<html>
	<head>
	</head>
	<body>
		<form action="popup.php" enctype="multipart/form-data" method="post">
			<table>
				<tr><td>Name: <br><input type="text" name="name"/></td></tr>
				<tr><td>Comment: </td></tr>
				<tr><td><textarea name="comment" rows="10" cols="50"></textarea></td></tr>
				<tr>
					<td>
						<input type='submit' name='submit' value='Comment'>
					</td>
				</tr>
			</table>
		</form>
		<?php
			$strSQL = "SELECT * FROM tbl_comments ORDER BY comment_id DESC";
			$rs = mysql_query($strSQL) or die(mysql_error());
			while($row = mysql_fetch_array($rs)){
			<table width="430px">
			<tr>
				<td colspan="2" valign="top">
					<?php
						echo "by "."<i>".$row['name']."</i>";
				</td>
			</tr>
			<tr>
				<td valign="top">
					<?php
						echo $row['comment'];
				</td>
				<td valign="top">
					<?php
						echo "<p align='right'>".$row['timestamp']."</p>";
				</td>
			</tr>
			<tr>
					<?php
						echo "Foreign key "."<i>".$row['aut_id']."</i>";
				</td>
			</tr>
			<hr size="1"/>
		</table>
		<?php } ?>
	</body>
</html>
Re: How to keep value received through GET method?
Posted: Sun Dec 02, 2012 11:49 pm
by Rksk
Ranura wrote:I want to keep the value "$aut_id" which is received through GET method.
<?php
    if($submit){
            FROM tbl_automobile
        }else{
<html>
    <head>
    </head>
    <body>
            <table>
                <tr>
                    <td>
                    </td>
                </tr>
            </table>
        </form>
        <?php
            <tr>
                    <?php
                </td>
            </tr>
            <tr>
                <td valign="top">
                    <?php
                </td>
                <td valign="top">
                    <?php
                </td>
            </tr>
            <tr>
                    <?php
                </td>
            </tr>
            <hr size="1"/>
        </table>
        <?php } ?>
    </body>
</html>
You haven't used any way to send $aut_id via POST or GET.
You may can send $aut_id via POST method my adding a hidden input box to your form.
<input type="hidden" name="aut_id" value="<?php echo $aut_id; ?>" />
Also you can send $aut_id via GET method by adding it to end of the URL.
<form action="popup.php?aut_id=<?php echo $aut_id; ?>" enctype="multipart/form-data" method="post">
Posted: Mon Dec 03, 2012 8:05 am
by Ranura
Thanks a lot for your help!!!
Found solution through your comments.
