Point of Sale printer/drawer & Customer Display source code
Posted: Sat Nov 28, 2009 6:26 am
Programme your own POS system - Part 3
Final part about ESC/POS is to learn how to call the routines specified by the printer/drawer and customer display files.
Open drawer:
Public Sub openDrawer(fnc As Byte)
'Dim tmp As String, ret As Integer
If DRStatus = 1 Then 'command to IODR
    tmp = genPulse(stt.gDRPin)
    ret = IODR.WriteData(tmp, Len(tmp))
    If fnc = 1 Then
        Call noSale
    End If
ElseIf DRStatus = 2 Then 'command to IO
    ret = IORP.WriteData(tmp, Len(tmp))
    If fnc = 1 Then
        Call noSale
    End If
End If
End Sub
Live bill printing with display items and cash drawer opening. (You will have to write your own database routines)
Public Sub noSale()
Dim rs As New Recordset
'save to disk
ADOCon.Execute "insert into daily_nskey values('" & clerkNo & "',#" & Format(Date & " " & Time, "mm/dd/yyyy hh:mm:ss") & "#,1)"
If stt.gablePrint <> 0 Then
    stt.getBTH font, Height, Width, Emp, Colour
    tmp = selectMode(font, Emp, Height, Width, 0, Colour)
    'information line   no sale    clerk   machine  date time
    tmp = tmp & "NOSALE "
    tmp = tmp & Left(clerkNo, 15) & Space(15 - Len(clerkNo)) & " "
    tmp = tmp & Format(Machine, "00") & " "
    tmp = tmp & Format(Date & " " & Time, "dd/mm/yy hh:mm") & lineFeed
    tmp = tmp & lineFeedN(7)
    If stt.gRPpCut = 1 Then 'partial
        tmp = tmp & setCut(1)
    ElseIf stt.gRPpCut = 2 Then 'full
        tmp = tmp & setCut(0)
    End If
End If
End Sub
Public Sub printRAPO()
Dim tot As Currency
'Dim font As Byte, Height As Byte, Width As Byte, Emp As Byte, Colour As Byte
rs.Open "select desn,rec_no,machine,t_date from ref_clerk,trans where rec_no='" & rec_no & "' and trans.clerk=ref_clerk.ck_code", ADOCon, adOpenStatic, adLockReadOnly
If rs.RecordCount <> 0 Then
    'information line   rec_no clerk   machine date    time
    tmp = tmp & Mid(rs!rec_no, 6, 5) & " "
    tmp = tmp & Left(rs!desn, 16) & Space(16 - Len(rs!desn)) & " "
    tmp = tmp & Format(rs!Machine, "00") & " "
    tmp = tmp & Format(rs!t_date, "dd/mm/yy hh:mm") & lineFeed
    tmp = tmp & String(40, "-") & lineFeed
    'rapo ( amounts )
    tmp = tmp & printRPO
    'Call printRPO
    End If
End If
End Sub
Public Sub printPBPay()
'Dim tmp As String, tmp1 As String, tmp2 As String, ret As Integer
Dim tmp1 As String, tmp2 As String
rs.Open "select ref_customer.c_Code + ' - ' + ref_customer.desn as [By CODE],ref_clerk.desn,ref_customer.balance,Trans.rec_no,machine,t_date from Trans,ref_clerk,Daily_PB_Pay,ref_customer where Trans.clerk=ref_clerk.ck_code and Trans.rec_no=Daily_PB_Pay.rec_no and Daily_PB_Pay.c_Code=ref_customer.c_Code and Trans.rec_no='" & rec_no & "'", ADOCon, adOpenStatic, adLockReadOnly
If rs.RecordCount <> 0 Then 'pb payment
    'Welcome text
    tmp = printWelcome & lineFeed
    tmp = tmp & selectMode(font, Emp, Height, Width, 0, Colour)
    'PB code & name
    'tmp = tmp & Left(rs![by code], 40 - (Len(Format(rs!balance, "0.00")) + 1))
    'tmp = tmp & Space(40 - (Len(Format(rs!balance, "0.00")) + Len(tmp))) & Format(rs!balance, "0.00") & lineFeed
    tmp1 = Format(rs!balance, "0.00")
    tmp2 = Left(rs![by code], 40 - (Len(tmp1) + 1))
    tmp = tmp & tmp2 & Space(40 - (Len(tmp1) + Len(tmp2))) & tmp1 & lineFeed
    'pb previouse balance
    tmp = tmp & selectMode(font, Emp, 1, Width, 0, Colour) 'double height
    tmp = tmp & printPreBalance(rs!balance)
    'payments ( + amounts )
    tmp = tmp & printPayments
    tmp = tmp & printBalance
    'pb current balance
    tmp = tmp & "New Balance " & Space(40 - (Len(tmp1) + 12)) & tmp1 & lineFeed
    tmp = tmp & selectMode(font, Emp, Height, Width, 0, Colour) & lineFeed
    'Goodbye text
    tmp = tmp & printGoodBye & lineFeed
    tmp = tmp & setJust(1)  'centre
    'tmp = tmp & "Software by DRT  011 4202420" & lineFeed
    tmp = tmp & "POS System By " & oemLine & Space(20 - Len(oemLine)) & " [DRT]" & lineFeed
    tmp = tmp & setJust(0)  'left
    End If
End If
End Sub
Public Sub printKitchen(IOKP As IO, isSM As Boolean, Optional sm_code As String, Optional sm_desn As String) '0-no KP 1 - stand alone hardware  3-with printer hardware
    If isSM = True Then tmp = tmp & sm_code & Space(40 - (Len(sm_code) + Len(sm_desn))) & sm_desn & lineFeed
    'items with respective discounts
    tmp = tmp & printItemDis
    'item counter
    tmp = tmp & printItemCounter
    End If
    ret = IOKP.WriteData(tmp, Len(tmp))
End If
End Sub
Public Sub DprintHeader(hdType As Byte, t_date As Date, isPB As Boolean, isSM As Boolean, Optional c_Code As String, Optional PB_Name As String, Optional balance As Currency, Optional sm_code As String, Optional sm_desn As String)
'hdType=0 Item bill    hdType=1  PBPayment
'Dim tmp As String, tmp1 As String, ret As Integer
Dim tmp1 As String
'Welcome text
'PB code & name
If isPB = True Then
    tmp1 = Left((c_Code & " - " & PB_Name), 40 - (Len(Format(balance, "0.00")) + 1))
    tmp = tmp & tmp1 & Space(40 - (Len(Format(balance, "0.00")) + Len(tmp1))) & Format(balance, "0.00") & lineFeed
End If
tmp = tmp & Mid(mncl.gRec_no, 6, 5) & " "
tmp = tmp & Left(clerkName, 16) & Space(16 - Len(clerkName)) & " "
tmp = tmp & Format(t_date, "dd/mm/yy hh:mm") & lineFeed
If hdType = 0 Then 'item bill
    tmp = tmp & "ITEM          PRICE      QTY      AMOUNT" & lineFeed
                'cccccccc sssssss.ss  qqqqqqq  aaaaaaa.aa
                '8        10          7           10
End If
End Sub
Public Sub DprintItemDis(plu_code As String, desn As String, qty As String, Rate As String, amt As String, isItmDis As Boolean, Optional Key As String, Optional dAmount As String)
'print item
tmp = desn & lineFeed
'print code,price,qty,amount
tmp = tmp & Right(plu_code, 8) & Space(8 - Len(plu_code)) & " "
tmp = tmp & Space(10 - Len(Rate)) & Rate & "  "
tmp = tmp & Space(7 - Len(qty)) & qty & "  "
tmp = tmp & Space(10 - Len(amt)) & amt & lineFeed
If isItmDis = True Then
    tmp = tmp & " ITM DIS  " & Left(Key, 20) & Space(20 - Len(Key)) & Space(10 - Len(dAmount)) & dAmount & lineFeed  'print discount
End If
End Sub
Public Sub DprintSubTDis(disStr As String)
tmp = lineFeed & disStr & lineFeed
End Sub
Public Sub DprintSTDVoid(disStr As String)
End Sub
Public Sub DprintTax(taxStr As String)
tmp = lineFeed & taxStr & lineFeed
End Sub
Public Sub DprintNetTotal(netStr As String)
tmp = lineFeed
stt.getBTH font, Height, Width, Emp, Colour 'to increse height & back
tmp = tmp & netStr & lineFeed
End Sub
Public Sub DprintPayments(prnStr As String)
tmp = prnStr & lineFeed
End Sub
Public Sub DPrintFooter(isPB As Boolean, Optional amount As Currency, Optional NB As Currency, Optional YouSave As Currency)
Dim tmp1 As String
tmp = ""
'credit to PB
If isPB = True Then
    tmp = selectMode(font, Emp, 1, Width, 0, Colour)
    tmp1 = Format(amount, "##0.00")
    tmp = tmp & "CREDIT TO PB" & Space(18) & Space(10 - Len(tmp1)) & Right(tmp1, 10) & lineFeed
    tmp1 = Format(NB, "##0.00")
    tmp = tmp & "NEW BALANCE" & Space(19) & Space(10 - Len(tmp1)) & Right(tmp1, 10) & lineFeed
End If
'item counter
tmp1 = mncl.Count
tmp = tmp & "ITEM COUNTER" & Space(28 - Len(tmp1)) & tmp1 & lineFeed & lineFeed
'total saving
If YouSave <> 0 Then
    tmp1 = "Rs. " & Format(-YouSave, "0.00")
    tmp = tmp & "Your saving on this invoice" & Space(13 - Len(tmp1)) & tmp1 & lineFeed & lineFeed
End If
'Goodbye text
tmp = tmp & "Software by ROBOT.LK Labs https://robot.lk" & lineFeed
'no logo printing in direct mode
End If
End Sub
Public Sub DprintVoid(cplu_code As String, cqty As String, cRate As String, camt As String, ctotDis As String)
tmp = tmp & "< < VOID > >" & lineFeed
tmp = tmp & Right(cplu_code, 8) & Space(8 - Len(cplu_code)) & " "
tmp = tmp & Space(10 - Len(cRate)) & cRate & "  "
tmp = tmp & Space(7 - Len(cqty)) & cqty & "  "
tmp = tmp & Space(10 - Len(camt)) & camt & lineFeed
If ctotDis <> "" Then tmp = tmp & " DISCOUNT VOID" & Space(40 - (Len(ctotDis) + 14)) & ctotDis & lineFeed
End Sub
Public Sub DprintErrCorrect(cplu_code As String, cqty As String, cRate As String, camt As String, ctotDis As String)
tmp = tmp & "< < ERROR CORRECT > >" & lineFeed
If Len(cqty) <= 7 Then tmp = tmp & Space(7 - Len(cqty)) & cqty & "  "
If Len(camt) <= 10 Then tmp = tmp & Space(10 - Len(camt)) & camt & lineFeed
End Sub
Public Sub DprintTrnVoid()
tmp = tmp & "< < RECEIPT VOID > >" & lineFeed
End If
End Sub
Public Sub PrintInvoice()
Dim tot As Currency, tot1 As Currency
Dim isPB As Boolean, isSM As Boolean
'Welcome text
rs.Open "select ref_customer.c_Code + ' - ' + ref_customer.desn as [By CODE]," & _
" ref_salesman.sm_Code,ref_salesman.desn as sm_desn,ref_clerk.desn,ref_customer.balance,Trans.rec_no,machine,t_date,amount" & _
" From Trans, ref_clerk, Daily_PB, ref_customer, ref_salesman, daily_sm" & _
" where Trans.clerk=ref_clerk.ck_code and Trans.rec_no=Daily_PB.rec_no and Daily_PB.c_Code=ref_customer.c_Code and" & _
" daily_sm.rec_no = Trans.rec_no And ref_salesman.sm_code = daily_sm.sm_code and Trans.rec_no='" & rec_no & "'", ADOCon, adOpenStatic, adLockReadOnly
If rs.RecordCount <> 0 Then 'pb & sm
    isPB = True
    isSM = True
Else 'no (pb or sm) > try sm
    Set rs = New Recordset
    rs.Open "select ref_salesman.sm_Code,ref_salesman.desn as sm_desn,ref_clerk.desn,Trans.rec_no,machine,t_date from Trans,ref_clerk,ref_salesman,daily_sm where Trans.clerk=ref_clerk.ck_code and daily_sm.rec_no=Trans.rec_no and ref_salesman.sm_code=daily_sm.sm_code and Trans.rec_no='" & rec_no & "'", ADOCon, adOpenStatic, adLockReadOnly
    If rs.RecordCount <> 0 Then 'sm found
        isPB = False
        isSM = True
    Else 'sm not found > try pb
        rs.Open "select ref_customer.c_Code + ' - ' + ref_customer.desn as [By CODE],ref_clerk.desn,ref_customer.balance,Trans.rec_no,machine,t_date,amount from Trans,ref_clerk,Daily_PB,ref_customer where Trans.clerk=ref_clerk.ck_code and Trans.rec_no=Daily_PB.rec_no and Daily_PB.c_Code=ref_customer.c_Code and Trans.rec_no='" & rec_no & "'", ADOCon, adOpenStatic, adLockReadOnly
            isPB = True
            isSM = False
        Else 'no sm no pb
            isPB = False
            isSM = False
        End If
    End If
End If
    'PB code & name
    If isPB = True Then
    End If
    If isSM = True Then tmp = tmp & rs!sm_code & Space(40 - (Len(rs!sm_code) + Len(rs!sm_desn))) & rs!sm_desn & lineFeed
                '8        10          7           10
    tot = 0
    tmp = tmp & printItemDis(tot) & lineFeed
    'sub total discounts
    tot1 = 0
    tmp = tmp & printSubTotDis(tot1)
    tot = tot + tot1
    'tax
    tot1 = 0
    tmp = tmp & printTax(tot1) & lineFeed
    tot = tot + tot1
    'net total
    tmp1 = Format(tot, "##0.00")
    tmp = tmp & "NET TOTAL " & Space(20) & Space(10 - Len(tmp1)) & Right(tmp1, 10) & lineFeed
    'balance if any ( - amounts )
    'credit to PB
    If isPB = True Then
        tmp1 = Format(rs!amount, "##0.00")
        tmp1 = Format(rs!balance, "##0.00")
    End If
    'item counter
    tmp = tmp & printItemCounter & lineFeed
End If
'You save
tmp = tmp & printYouSave
'Goodbye text
End If
End Sub
Private Function printWelcome() As String
Dim tmp1 As String
printWelcome = setJust(1) 'centre
'stt.gWM1
tmp1 = stt.gWM1
If tmp1 <> "0" Then
    stt.getWM1H font, Height, Width, Emp, Colour
    printWelcome = printWelcome & selectMode(font, Emp, Height, Width, 0, Colour)
    printWelcome = printWelcome & tmp1 & lineFeed
End If
'stt.gWM2
tmp1 = stt.gWM2
If tmp1 <> "0" Then
    stt.getWM2H font, Height, Width, Emp, Colour
End If
'stt.gWM3
tmp1 = stt.gWM3
If tmp1 <> "0" Then
    stt.getWM3H font, Height, Width, Emp, Colour
End If
'stt.gWM4
tmp1 = stt.gWM4
If tmp1 <> "0" Then
    stt.getWM4H font, Height, Width, Emp, Colour
End If
'stt.gWM5
tmp1 = stt.gWM5
If tmp1 <> "0" Then
    stt.getWM5H font, Height, Width, Emp, Colour
End If
'stt.gWM6
tmp1 = stt.gWM6
If tmp1 <> "0" Then
    stt.getWM6H font, Height, Width, Emp, Colour
End If
printWelcome = printWelcome & setJust(0)  'left
End Function
Private Function printGoodBye() As String
Dim tmp1 As String
printGoodBye = setJust(1) 'centre
'stt.gGM1
tmp1 = stt.gGM1
If tmp1 <> "0" Then
    stt.getGM1H font, Height, Width, Emp, Colour
    printGoodBye = printGoodBye & selectMode(font, Emp, Height, Width, 0, Colour)
    printGoodBye = printGoodBye & tmp1 & lineFeed
End If
'stt.gGM2
tmp1 = stt.gGM2
If tmp1 <> "0" Then
    stt.getGM2H font, Height, Width, Emp, Colour
End If
'stt.gGM3
tmp1 = stt.gGM3
If tmp1 <> "0" Then
    stt.getGM3H font, Height, Width, Emp, Colour
End If
printGoodBye = printGoodBye & setJust(0)  'left
End Function
Private Function printItemDis(Optional tot As Currency) As String
Dim rsB As New Recordset
Dim tmp1 As String
rs.Open "SELECT ref_plu.PLU_Code, ref_plu.PLU_Desn, Daily_Sales.Qty, Daily_Sales.Amount, Daily_Plus_Minus.Key, ref_disc.Desn AS dDesn, Daily_Plus_Minus.Amount AS dAmount " & _
"FROM ((ref_plu INNER JOIN Daily_Sales ON ref_plu.PLU_Code = Daily_Sales.plu_code) LEFT JOIN Daily_Plus_Minus ON (cstr(Daily_Sales.CNT) = Daily_Plus_Minus.Status) AND (Daily_Sales.rec_no = Daily_Plus_Minus.rec_no)) LEFT JOIN ref_disc ON Daily_Plus_Minus.Key = ref_disc.Code " & _
"WHERE Daily_Sales.rec_no='" & rec_no & "' " & _
"ORDER BY Daily_Sales.CNT", ADOCon, adOpenStatic, adLockReadOnly
Do While Not rs.EOF
    'print item
    printItemDis = printItemDis & rs!plu_desn & lineFeed
    printItemDis = printItemDis & Right(rs!plu_code, 8) & Space(8 - Len(rs!plu_code)) & " "
    If rs!qty <> 0 Then
        tmp1 = Format(Round(CCur(rs!amount) / CDbl(rs!qty), 2), "##0.00")
    Else
        tmp1 = "0.00"
    End If
    printItemDis = printItemDis & Space(10 - Len(tmp1)) & tmp1 & "  "
    tmp1 = rs!qty
    printItemDis = printItemDis & Space(7 - Len(tmp1)) & tmp1 & "  "
    printItemDis = printItemDis & lineFeed
    tot = tot + rs!amount
    If IsNull(rs!Key) = False Then
        printItemDis = printItemDis & " ITM DIS  "
        tmp1 = Format(rs!dAmount, "##0.00")
        printItemDis = printItemDis & Left(rs!dDesn, 20) & Space(20 - Len(rs!dDesn)) & Space(10 - Len(tmp1))
        printItemDis = printItemDis & tmp1
        tot = tot + rs!dAmount
    End If
    rs.MoveNext
Loop
End Function
Private Function printSubTotDis(Optional tot As Currency) As String
Dim tmp1 As String
rs.Open "select rec_no,[key] as code,desn,status,sum(amount) as samount " & _
"From daily_plus_minus, ref_disc " & _
"where rec_no='" & rec_no & "' and status='SubTot' and ref_disc.code=daily_plus_minus.[key] " & _
"group by rec_no,[key],desn,status", ADOCon, adOpenStatic, adLockReadOnly
Do While Not rs.EOF
    printSubTotDis = printSubTotDis & "SUBT DIS "
    tmp1 = Format(rs!samount, "##0.00")
    printSubTotDis = printSubTotDis & Left(rs!desn, 21) & Space(21 - Len(rs!desn)) & Space(10 - Len(tmp1))
    printSubTotDis = printSubTotDis & tmp1
    printSubTotDis = printSubTotDis & lineFeed
    tot = tot + rs!samount
    rs.MoveNext
Loop
End Function
Private Function printTax(Optional tot As Currency) As String
Dim tmp1 As String
rs.Open "select desn,amount " & _
"From daily_tax,ref_tax " & _
"where daily_tax.t_code=ref_tax.t_code and rec_no='" & rec_no & "' order by daily_tax.t_code", ADOCon, adOpenStatic, adLockReadOnly
Do While Not rs.EOF
    printTax = printTax & Left(rs!desn, 20) & Space(20 - Len(rs!desn)) & Space(10 - Len(tmp1))
    printTax = printTax & tmp1
    printTax = printTax & lineFeed
    rs.MoveNext
Loop
End Function
Private Function printPayments() As String
Dim tmp1 As String
rs.Open "select rec_no,daily_tot.m_code,desn,sum(amount) as samount " & _
"From daily_tot, ref_mode " & _
"Where rec_no='" & rec_no & "' and Amount > 0 And daily_tot.m_code = ref_mode.m_code " & _
"group by rec_no,daily_tot.m_code,desn", ADOCon, adOpenStatic, adLockReadOnly
Do While Not rs.EOF
    tmp1 = rs!desn & Space(30 - Len(rs!desn)) & Space(10 - Len(tmp1)) & Right(tmp1, 10)
    printPayments = printPayments & tmp1 & lineFeed
    rs.MoveNext
Loop
End Function
Private Function printBalance() As String
Dim tmp1 As String
rs.Open "select rec_no,desn,sum(amount) as samount " & _
"Where rec_no='" & rec_no & "' and Amount < 0 And daily_tot.m_code = ref_mode.m_code " & _
"group by rec_no,desn", ADOCon, adOpenStatic, adLockReadOnly
    tmp1 = Format(-rs!samount, "##0.00")
    tmp1 = "BALANCE" & Space(23) & Space(10 - Len(tmp1)) & Right(tmp1, 10)
    printBalance = tmp1 & lineFeed
End If
End Function
Private Function printItemCounter() As String
rs.Open "select rec_no,daily_sales.plu_code,ref_plu.plu_desn,sum(daily_sales.qty) as sqty,sum(amount) as samount " & _
"from daily_sales,ref_plu " & _
"where daily_sales.rec_no='" & rec_no & "' and Daily_sales.plu_code=ref_plu.plu_code " & _
"group by rec_no,daily_sales.plu_code,plu_desn", ADOCon, adOpenStatic, adLockReadOnly
    printItemCounter = "ITEM COUNTER" & Space(28 - Len(CStr(rs.RecordCount))) & rs.RecordCount & lineFeed
End If
End Function
Private Function printYouSave() As String
Dim tmp1 As String
rs.Open "select sum(amount) as samount " & _
"From daily_plus_minus " & _
"where rec_no='" & rec_no & "' " & _
"group by rec_no", ADOCon, adOpenStatic, adLockReadOnly
    If rs!samount <> 0 Then
        tmp1 = "Rs. " & Format(-rs!samount, "##0.00")
        printYouSave = "Your saving on this invoice" & Space(13 - Len(tmp1)) & tmp1 & lineFeed & lineFeed
    End If
End If
End Function
Private Function printPreBalance(curBalance As Currency) As String
Dim tmrs As New Recordset
Dim tmp1 As String
Dim tot As Currency
tmrs.Open "select sum(amount) as tot from daily_tot where rec_no='" & rec_no & "' group by rec_no", ADOCon, adOpenStatic, adLockReadOnly
If tmrs.RecordCount <> 0 Then
    tot = tmrs!tot
Else
    tot = 0
End If
tmp1 = Format(curBalance + tot, "0.00")
printPreBalance = "Previous Balance " & Space(40 - (Len(tmp1) + 17)) & tmp1 & lineFeed
End Function
Private Function printRPO() As String
Dim tmp1 As String
rs.Open "select cash_tray.rec_no,cash_tray.r_code,desn,status,amount " & _
"From cash_tray, ref_rapo, daily_tot " & _
"Where cash_tray.rec_no='" & rec_no & "' and cash_tray.rec_no=daily_tot.rec_no and cash_tray.r_code = ref_rapo.r_code", ADOCon, adOpenStatic, adLockReadOnly
    If rs!Status = 0 Then
    Else
        tmp1 = Format(-rs!amount, "##0.00")
    End If
    printRPO = printRPO & tmp1 & lineFeed
End If
End Function
Public Sub PrintDailyT(cCloseBalance As Currency)
Dim txt As String, txt1 As String
Dim totSales As Currency, totReturns As Currency
Dim curDiscount As Currency, totDiscount As Currency
Dim curTax As Currency, totTax As Currency
Dim curPay As Currency, totPay As Currency
Dim totRA As Currency, totPO As Currency
Dim totCash As Currency
Dim dtSignIn As Date, dtSignOut As Date
Dim openBalance As Currency, closeBalance As Currency
Dim noOfBills As Integer, noOfRets As Integer, noOfOpens As Integer, noOfCancels As Integer
tmrs.Open "select * from daily_signin where c_code='" & clerkNo & "' and process=0", ADOCon, adOpenStatic, adLockReadOnly
    dtSignIn = tmrs!SignIn
    dtSignOut = Date + Time
    openBalance = tmrs!openBal
'    closeBalance = tmrs!closeBal
    noOfBills = tmrs!noOfBills
    noOfRets = tmrs!noOfRets
    noOfOpens = tmrs!noOfOpens
    noOfCancels = tmrs!noOfCancels
End If
tmp = tmp & "Daily Terminal Report" & lineFeed
tmp = tmp & "---------------------" & lineFeed
tmp = tmp & "Clerk      : " & clerkName & lineFeed
'If Machine = 1 Then
'    tmp = tmp & "Station ID : " & Machine & "    BORELLA" & lineFeed
'ElseIf Machine = 2 Then
'    tmp = tmp & "Station ID : " & Machine & "    DEHIWALA" & lineFeed
'End If
tmp = tmp & "Sign-In    : " & dtSignIn & lineFeed
tmp = tmp & "Sign-Out   : " & dtSignOut & lineFeed
tmp = tmp & "----------------------------------------" & lineFeed
txt = Format(openBalance, "0.00")
tmp = tmp & "Opening Balance" & Space(40 - (Len(txt) + 15)) & txt & lineFeed
'dtSignIn = DateValue
'Total RA
txt = "0.00"
totRA = 0
Set tmrs = New Recordset
tmrs.Open "select desn,sum(amount) as amt from cash_tray,ref_rapo,daily_tot,trans where status=0 and cash_tray.r_code=ref_rapo.r_code and cash_tray.rec_no=daily_tot.rec_no and cash_tray.rec_no=trans.rec_no and t_date >= #" & Format(dtSignIn, "mm/dd/yyyy hh:mm") & "# and t_date <= #" & Format(dtSignOut, "mm/dd/yyyy hh:mm") & "# and clerk='" & clerkNo & "' and machine=" & Machine & " group by datevalue(t_date),machine,ref_rapo.r_code,ref_rapo.desn", ADOCon, adOpenStatic, adLockReadOnly
Do While Not tmrs.EOF
    txt1 = tmrs!desn
    txt = Format(tmrs!amt, "###0.00")
    'print
    tmp = tmp & " " & txt1 & Space(40 - (Len(txt) + Len(txt1) + 1)) & txt & lineFeed
    totRA = totRA + tmrs!amt
    tmrs.MoveNext
Loop
'print
txt = Format(totRA, "0.00")
tmp = tmp & "Total R/A" & Space(40 - (Len(txt) + 9)) & txt & lineFeed & lineFeed
'Total PO
txt = "0.00"
totPO = 0
tmrs.Open "select desn,sum(amount) as amt from cash_tray,ref_rapo,daily_tot,trans where status=1 and cash_tray.r_code=ref_rapo.r_code and cash_tray.rec_no=daily_tot.rec_no and cash_tray.rec_no=trans.rec_no and t_date >= #" & Format(dtSignIn, "mm/dd/yyyy hh:mm") & "# and t_date <= #" & Format(dtSignOut, "mm/dd/yyyy hh:mm") & "# and clerk='" & clerkNo & "' and machine=" & Machine & " group by datevalue(t_date),machine,ref_rapo.r_code,ref_rapo.desn", ADOCon, adOpenStatic, adLockReadOnly
    txt1 = tmrs!desn
    txt = Format(-tmrs!amt, "###0.00")
    'print
    totPO = totPO + -tmrs!amt
    tmrs.MoveNext
Loop
'print
txt = Format(totPO, "0.00")
tmp = tmp & "Total P/O" & Space(40 - (Len(txt) + 9)) & txt & lineFeed & lineFeed
'Total sales
txt = "0.00"
tmrs.Open "select sum(amount) as amt from daily_sales,trans where daily_sales.rec_no=trans.rec_no and amount>=0 and t_date >= #" & Format(dtSignIn, "mm/dd/yyyy hh:mm") & "# and t_date <= #" & Format(dtSignOut, "mm/dd/yyyy hh:mm") & "# and clerk='" & clerkNo & "' and machine=" & Machine & " group by datevalue(t_date),machine", ADOCon, adOpenStatic, adLockReadOnly
    totSales = tmrs!amt
    txt = Format(totSales, "###0.00")
End If
'print
tmp = tmp & " Sales" & Space(40 - (Len(txt) + 6)) & txt & lineFeed
txt = "0.00"
'Total returns
tmrs.Open "select sum(amount) as amt from daily_sales,trans where daily_sales.rec_no=trans.rec_no and amount<0 and t_date >= #" & Format(dtSignIn, "mm/dd/yyyy hh:mm") & "# and t_date <= #" & Format(dtSignOut, "mm/dd/yyyy hh:mm") & "# and clerk='" & clerkNo & "' and machine=" & Machine & " group by datevalue(t_date),machine", ADOCon, adOpenStatic, adLockReadOnly
    totReturns = tmrs!amt
    txt = Format(totReturns, "###0.00")
End If
'print
tmp = tmp & " Returns" & Space(40 - (Len(txt) + 8)) & txt & lineFeed
'Daily Sales
'print
txt = Format((totSales + totReturns), "###0.00")
tmp = tmp & "Daily Sales" & Space(40 - (Len(txt) + 11)) & txt & lineFeed & lineFeed
'Discounts
tmrs.Open "select [key]as K,sum(amount) as amt from daily_plus_minus,trans where daily_plus_minus.rec_no=trans.rec_no and t_date >= #" & Format(dtSignIn, "mm/dd/yyyy hh:mm") & "# and t_date <= #" & Format(dtSignOut, "mm/dd/yyyy hh:mm") & "# and clerk='" & clerkNo & "' and machine=" & Machine & " group by datevalue(t_date),machine,[key] order by [key]", ADOCon, adOpenStatic, adLockReadOnly
    curDiscount = tmrs!amt
    txt = Format(curDiscount, "###0.00")
    txt1 = tmrs!k
    'print
    totDiscount = totDiscount + curDiscount
    tmrs.MoveNext
Loop
'Total Discount
'print
txt = Format(totDiscount, "###0.00")
tmp = tmp & "Daily Discounts" & Space(40 - (Len(txt) + 15)) & txt & lineFeed & lineFeed
'Tax
tmrs.Open "select desn,sum(amount) as amt from daily_tax,ref_tax,trans where daily_tax.t_code=ref_tax.t_code and daily_tax.rec_no=trans.rec_no and t_date >= #" & Format(dtSignIn, "mm/dd/yyyy hh:mm") & "# and t_date <= #" & Format(dtSignOut, "mm/dd/yyyy hh:mm") & "# and clerk='" & clerkNo & "' and machine=" & Machine & " group by datevalue(t_date),machine,daily_tax.t_code,desn order by daily_tax.t_code", ADOCon, adOpenStatic, adLockReadOnly
    curTax = tmrs!amt
    txt = Format(curTax, "###0.00")
    txt1 = tmrs!desn
    'print
    totTax = totTax + curTax
    tmrs.MoveNext
Loop
'Total Tax
'print
txt = Format(totTax, "###0.00")
tmp = tmp & "Daily Tax" & Space(40 - (Len(txt) + 9)) & txt & lineFeed & lineFeed
'Credit to PB
txt = "0.00"
tmrs.Open "select sum(amount) as amt from daily_pb,trans where daily_pb.rec_no=trans.rec_no and t_date >= #" & Format(dtSignIn, "mm/dd/yyyy hh:mm") & "# and t_date <= #" & Format(dtSignOut, "mm/dd/yyyy hh:mm") & "# and clerk='" & clerkNo & "' and machine=" & Machine & " group by datevalue(t_date),machine", ADOCon, adOpenStatic, adLockReadOnly
End If
'print
tmp = tmp & "Credit to PB" & Space(40 - (Len(txt) + 12)) & txt & lineFeed
'PB Payments
txt = "0.00"
tmrs.Open "select sum(amount) as amt from daily_pb_Pay,Daily_tot,trans where daily_pb_Pay.rec_no=Daily_Tot.rec_no and daily_pb_Pay.rec_no=trans.rec_no and t_date >= #" & Format(dtSignIn, "mm/dd/yyyy hh:mm") & "# and t_date <= #" & Format(dtSignOut, "mm/dd/yyyy hh:mm") & "# and clerk='" & clerkNo & "' and machine=" & Machine & " group by datevalue(t_date),machine", ADOCon, adOpenStatic, adLockReadOnly
End If
'print
tmp = tmp & "PB Payments" & Space(40 - (Len(txt) + 11)) & txt & lineFeed & lineFeed
'Payments
tmrs.Open "select ref_mode.m_code,desn,sum(amount) as amt from daily_tot,trans,ref_mode where ref_mode.m_code=daily_tot.m_code and daily_tot.rec_no=trans.rec_no and t_date >=#" & Format(dtSignIn, "mm/dd/yyyy hh:mm") & "# and t_date <= #" & Format(dtSignOut, "mm/dd/yyyy hh:mm") & "# and clerk='" & clerkNo & "' and machine=" & Machine & " group by datevalue(t_date),machine,ref_mode.m_code,desn order by ref_mode.m_code", ADOCon, adOpenStatic, adLockReadOnly
    If tmrs!m_code = 1 Then
        totCash = tmrs!amt
        curPay = totCash - totRA + totPO
    Else
        curPay = tmrs!amt
    End If
    txt = Format(curPay, "###0.00")
    txt1 = tmrs!desn
    'print
    totPay = totPay + curPay
    tmrs.MoveNext
Loop
'total Payments
'print
txt = Format(totPay, "###0.00")
tmp = tmp & "Total Payments" & Space(40 - (Len(txt) + 14)) & txt & lineFeed & lineFeed
'total cash on tray
'txt = Format(totCash, "###0.00")
'tmp = tmp & "Cash TRNs" & Space(40 - (Len(txt) + 9)) & txt & lineFeed
tmp = tmp & "Total Cash Tray" & Space(40 - (Len(txt) + 15)) & txt & lineFeed
txt = Format(cCloseBalance, "###0.00")
tmp = tmp & "Closing Balance" & Space(40 - (Len(txt) + 15)) & txt & lineFeed
txt = Format(totCash - cCloseBalance, "###0.00")
tmp = tmp & "Varience" & Space(40 - (Len(txt) + 8)) & txt & lineFeed
txt = noOfBills
tmp = tmp & "No Of Bills" & Space(40 - (Len(txt) + 11)) & txt & lineFeed
txt = noOfRets
tmp = tmp & "No Of Returns" & Space(40 - (Len(txt) + 13)) & txt & lineFeed
txt = noOfOpens
tmp = tmp & "No Of Opens" & Space(40 - (Len(txt) + 11)) & txt & lineFeed
txt = noOfCancels
tmp = tmp & "No Of Cancels" & Space(40 - (Len(txt) + 13)) & txt & lineFeed
End If
End Sub
Public Sub normalPrintDailyT()
'Total RA
txt = "0.00"
totRA = 0
tmrs.Open "select desn,sum(amount) as amt from cash_tray,ref_rapo,daily_tot,trans where status=0 and cash_tray.r_code=ref_rapo.r_code and cash_tray.rec_no=daily_tot.rec_no and cash_tray.rec_no=trans.rec_no and datevalue(t_date)=#" & Format(Date, "mm/dd/yyyy") & "# and machine=" & Machine & " group by datevalue(t_date),machine,ref_rapo.r_code,ref_rapo.desn", ADOCon, adOpenStatic, adLockReadOnly
    txt1 = tmrs!desn
    'print
    tmrs.MoveNext
Loop
'print
'Total PO
txt = "0.00"
totPO = 0
tmrs.Open "select desn,sum(amount) as amt from cash_tray,ref_rapo,daily_tot,trans where status=1 and cash_tray.r_code=ref_rapo.r_code and cash_tray.rec_no=daily_tot.rec_no and cash_tray.rec_no=trans.rec_no and datevalue(t_date)=#" & Format(Date, "mm/dd/yyyy") & "# and machine=" & Machine & " group by datevalue(t_date),machine,ref_rapo.r_code,ref_rapo.desn", ADOCon, adOpenStatic, adLockReadOnly
    txt1 = tmrs!desn
    'print
    tmrs.MoveNext
Loop
'print
'Total sales
txt = "0.00"
tmrs.Open "select sum(amount) as amt from daily_sales,trans where daily_sales.rec_no=trans.rec_no and amount>=0 and datevalue(t_date)=#" & Format(Date, "mm/dd/yyyy") & "# and machine=" & Machine & " group by datevalue(t_date),machine", ADOCon, adOpenStatic, adLockReadOnly
    totSales = tmrs!amt
End If
'print
txt = "0.00"
'Total returns
tmrs.Open "select sum(amount) as amt from daily_sales,trans where daily_sales.rec_no=trans.rec_no and amount<0 and datevalue(t_date)=#" & Format(Date, "mm/dd/yyyy") & "# and machine=" & Machine & " group by datevalue(t_date),machine", ADOCon, adOpenStatic, adLockReadOnly
End If
'print
'Daily Sales
'print
'Discounts
tmrs.Open "select [key]as K,sum(amount) as amt from daily_plus_minus,trans where daily_plus_minus.rec_no=trans.rec_no and datevalue(t_date)=#" & Format(Date, "mm/dd/yyyy") & "# and machine=" & Machine & " group by datevalue(t_date),machine,[key] order by [key]", ADOCon, adOpenStatic, adLockReadOnly
    txt1 = tmrs!k
    'print
    tmrs.MoveNext
Loop
'Total Discount
'print
'Tax
tmrs.Open "select desn,sum(amount) as amt from daily_tax,ref_tax,trans where daily_tax.t_code=ref_tax.t_code and daily_tax.rec_no=trans.rec_no and datevalue(t_date)=#" & Format(Date, "mm/dd/yyyy") & "# and machine=" & Machine & " group by datevalue(t_date),machine,daily_tax.t_code,desn order by daily_tax.t_code", ADOCon, adOpenStatic, adLockReadOnly
    curTax = tmrs!amt
    txt1 = tmrs!desn
    'print
    tmrs.MoveNext
Loop
'Total Tax
'print
'Credit to PB
txt = "0.00"
tmrs.Open "select sum(amount) as amt from daily_pb,trans where daily_pb.rec_no=trans.rec_no and datevalue(t_date)=#" & Format(Date, "mm/dd/yyyy") & "# and machine=" & Machine & " group by datevalue(t_date),machine", ADOCon, adOpenStatic, adLockReadOnly
End If
'print
'PB Payments
txt = "0.00"
tmrs.Open "select sum(amount) as amt from daily_pb_Pay,Daily_tot,trans where daily_pb_Pay.rec_no=Daily_Tot.rec_no and daily_pb_Pay.rec_no=trans.rec_no and datevalue(t_date)=#" & Format(Date, "mm/dd/yyyy") & "# and machine=" & Machine & " group by datevalue(t_date),machine", ADOCon, adOpenStatic, adLockReadOnly
End If
'print
'Payments
tmrs.Open "select ref_mode.m_code,desn,sum(amount) as amt from daily_tot,trans,ref_mode where ref_mode.m_code=daily_tot.m_code and daily_tot.rec_no=trans.rec_no and datevalue(t_date)=#" & Format(Date, "mm/dd/yyyy") & "# and machine=" & Machine & " group by datevalue(t_date),machine,ref_mode.m_code,desn order by ref_mode.m_code", ADOCon, adOpenStatic, adLockReadOnly
        totCash = tmrs!amt
    Else
        curPay = tmrs!amt
    End If
    txt1 = tmrs!desn
    'print
    tmrs.MoveNext
Loop
'total Payments
'print
tmp = tmp & "Daily Payments" & Space(40 - (Len(txt) + 14)) & txt & lineFeed & lineFeed
'total cash on tray
tmp = tmp & "Total CashTray" & Space(40 - (Len(txt) + 14)) & txt & lineFeed & lineFeed
End If
End Sub
Public Sub printSalesSummary()
Dim totCash As Currency, totRA As Currency, totPO As Currency, curPay As Currency, totPay As Currency
Dim txt As String, txt1 As String, tmp1 As String
End If
'tmp = printWelcome & lineFeed
tmp = tmp & "SALES SUMMARY" & lineFeed
If Machine = 1 Then
End If
tmp = tmp & "Date       : " & Date & lineFeed
'Total RA
txt = "0.00"
totRA = 0
    txt1 = tmrs!desn
    'print
'    tmp = tmp & " " & txt1 & Space(40 - (Len(txt) + Len(txt1) + 1)) & txt & lineFeed
    tmrs.MoveNext
Loop
'Total PO
txt = "0.00"
totPO = 0
    txt1 = tmrs!desn
    'print
    tmrs.MoveNext
Loop
tmrs.Open "select ref_mode.m_code,desn,sum(amount) as amt from daily_tot,trans,ref_mode where ref_mode.m_code=daily_tot.m_code and daily_tot.rec_no=trans.rec_no and t_date >= #" & Format(dtSignIn, "mm/dd/yyyy hh:mm") & "# and t_date <= #" & Format(dtSignOut, "mm/dd/yyyy hh:mm") & "# and clerk='" & clerkNo & "' and machine=" & Machine & " group by datevalue(t_date),machine,ref_mode.m_code,desn order by ref_mode.m_code", ADOCon, adOpenStatic, adLockReadOnly
        totCash = tmrs!amt
    Else
        curPay = tmrs!amt
    End If
    txt1 = tmrs!desn
    'print
    tmrs.MoveNext
Loop
End If
End Sub
Please make sure that you post a reply to say thanks if it works okay for you. :)
See also:
ESC/POS printer source code at https://robot.lk/viewtopic.php?f=39&t=874
ESC/POS Customer Display source code at https://robot.lk/viewtopic.php?f=39&t=875
Barcode printer source code at https://robot.lk/viewtopic.php?f=39&t=877
