Installing and Administrating a Eucalyptus Cloud Computing
Posted: Tue Sep 17, 2013 6:33 pm
by nwclasantha
You have To Request the PDF file if anyone needed bez the file size is more than 3MB accordingly,any how this site has a limitation for uploading upto 2MB Max limit .
Therefore you just mail me [email protected] to receive this PDF asap.
BR,
Chanaka
Re: Installing and Administrating a Eucalyptus Cloud Computing
Posted: Fri Sep 20, 2013 4:36 am
by SemiconductorCat
regarding that, there is a bbcode for publishing pdf files.
The code is,
[pdfview][/pdfview]
Let's test it here by loading AD dialog PDF file.
If I/you see this work then it should work.
[pdfview]http://www.analog.com/library/analogdia ... ol45n3.pdf[/pdfview]
if lucky...
tested and it doesn't appear like code work. May be pdf2 bbcode converter may work nice
here. Any other alternatives?
Posted: Fri Sep 20, 2013 4:51 pm
As mentioned Chanaka, the best way is to compress it to be few 2MB or 1MB files.
Posted: Fri Sep 20, 2013 9:14 pm
by nwclasantha
m
