Linux Process Management Basics
Posted: Mon Jun 20, 2011 10:01 am
A process can be identified as a set of instructions loaded to the memory. Every process has UID and GID.
Who is the owner of the ‘firefox’ program?
Observe,
Get PID, Executed User, Real User, Common Name
Get PID, %CPU, % MEM, Executed User, Real User, Common Name
find the parent process
What is a Signal in Linux
This a UNIX concept which is used to inter-process communication. Using Signal can send a message directly to a process. There are many Signal types are available. Most frequently use signal are;
HUP (1) -> re-read the config file
KILL (9) -> Terminate immediately
TERM (15) -> Terminate gracefully
Further, observe
Command use for sending Signals
Exersises:
Observe:
1.
2.
3.
Start Stop Services
All init script of the process are usually in /etc unless if you have given a installing prefix when compiling the packages.
How to use;
OR
Start Stop service while Boot and Shutdown time
At the booting process kernel start the init process, which is the master process of the system. Then read the /etc/inittab to decide the default runlevel.
Observ:
# Default runlevel. The runlevels used are:
# 0 - halt (Do NOT set initdefault to this)
# 1 - Single user mode
# 2 - Multiuser, without NFS (same as 3, do not have networking)
# 3 - Full multiuser mode
# 4 - unused
# 5 - X11
# 6 - reboot (Do NOT set initdefault to this)
id:5:initdefault: # default runlevel
According to the runlevel defined the appropriate directory is used to run the initial script.
Observ:
Anatomy of the init scripts
Create a script to start at the beginning will be discussed later on
stat /usr/bin/firefox
	stat $(which firefox)Observe,
ps axo pid,euser,ruser,comm |grep firefox
ps axo pid,euser,ruser,comm |egrep ‘init|firefox’
	ps axo pid,%cpu,%mem,tty,euser,ruser,comm |lessfind the parent process
pstree |lessWhat is a Signal in Linux
Further, observe
man 7 signalCode: Select all
kill
killall
pkill
pgrep
Observe:
1.
        $ pgrep crond
	$ pgrep cupsd
	# kill -HUP $(pgrep crond)
	# kill -HUP $(pgrep cupsd)
	$ pgrep crond	-> has PID got changed?
	$ pgrep cupsd  	-> has PID got changed?
	# kill -9 $(pgrep cupsd)
	$ pgrep cupsd
	# service crond start
	$ pgrep crond 	-> check the PIDCode: Select all
        $ firefox &
	$ killall firefox		->Observe the firefox
	$ pkill firefox
$ firefox
	$ ctrl + z
	$ jobs 	-> find the job id
	$ bg %1	-> resume the background process 1
	$ fg %1
	$ kill %1Start Stop Services
How to use;
/etc/init.d/servicename start|stop|reload|restart|statusCode: Select all
service servicename start|stop|reload|restart|statusStart Stop service while Boot and Shutdown time
Observ:
cat /etc/inittab|
# 4 - unused
# 5 - X11
				|- rc0.d
				|- rc1.d
				|- rc2.d
	/etc/rc.d/|- rc3.d
				|- rc4.d
				|- rc5.d
				|- rc6.d
Observ:
	ls -al /etc/rc.d/rc5.dCode: Select all
K95cgconfig -> ../init.d/cgconfig
K95firstboot -> ../init.d/firstboot
S02lvm2-monitor -> ../init.d/lvm2-monitor
S07iscsid -> ../init.d/iscsidAnatomy of the init scripts
                     S 07 iscsid
S for start at boot _|	|	|_  init script
K dont start		|_ prority level
