Micro-controllers for day-to-day life (Sinhala Medium)
Posted: Thu Apr 29, 2010 11:39 pm
by Rksk
Learn PIC Micro-controllers in Sinhala.
There are lots of articles wich published on Vidusara Science News Paper.
Course introduction
Summary (I) to (X)
Introduction to Microcontrollers
Internal Architecture
I/O Ports Fetch, Decode, and Execute
Controlling and processing unit
Softwares used for Programming Microcontrollers
Compilers and Integrated Development Environments
How to build your own JDM Programmer (I)
How to build your own JDM Programmer (II)
Hardware needed for Programming
Program using ICPROG Software
Build your first microcontroller based circuit
Typical microcontroller assembly circuit diagram
Special Function registers of the Microcontroller PIC16F84A
Creating your first assembly code
How to write assembly code in MPLAB
More on MPLAB
How to simulate using MPLAB SIM
LED Pattern generators
Assembly code for driving 8 LEDs (I)
Assembly code for driving 8 LEDs (II)
Driving 40 LEDs using PORT multiplexing (8x5)
How to display a Character using 8x5 LED matrix
Seven Segment Displays
Driving segments using PORT-B I/O
Basic counter circuit (I)
0 – 100 up counter using two SSD (I)
0 – 100 up counter using two SSD (II)
Usage of interrupts
Practical usage of Interrupts
External Interrupts
Connecting a microcontroller with the PC
PC Serial port overview
Logic level translation using MAX 232 IC
Assembly code for controlling USART module (I)
Assembly code for controlling USART module (II)
Analog to Digital conversion
Temperature Logger using LM35
Importance of Quantization error and Sampling rate
PIC16F877A ADCON0 and ADCON1register
A/D, show results using SSD
Assembly code for A/D conversion (I)
Assembly code for A/D conversion (II)
Send A/D converted data through RS-232
Liquid Crystal Displays
Types of LCDs
Running a LCD module using PIC16F84A (I)
Running a LCD module using PIC16F84A (II)
Running a LCD module using PIC16F84A (III)
Number representations
Introduction to Binary, Octal and Hex number systems
Logic gates and Boolean algebra
Boolean algebra and Registers
Communication using Ascii codes
DC Motor controlling
Controlling a DC motor using H-Bridge IC L298
Control rotation speed, rotation direction using Microcontroller
Connecting the DC motor controller to PC
DC motor control according to the user press buttons
Pulse Width Modulation (PWM)
Calculating the DC Motor rotation speed (RPM)
Dynamic control using feedback loops
Remote controllersnumbering>
The electromagnetic spectrum
Infrared remote controllers
IR Sensors
How to capture the IR receiver signal using Microcontroller
Decoding IR Signals (I)
Decoding IR Signals (II)
Decoding IR Signal algorithm
Data transfer between digital circuits
Serial Peripheral Interface (I)
Serial Peripheral Interface (II)
Nokia 3310 LCD Driving using SPI (I)
Nokia 3310 LCD Driving using SPI (II)
Connecting a Nokia 3310 LCD to PIC16F877A
Assembly code for LCD driving (I)
Assembly code for LCD driving (II)
Sinhala characters in a Nokia 3310 LCD
Animation effects with Nokia 3310 LCD
How to use high level languages
Introduction
C code for blinking a LED
C code for driving 8 LEDs (I)
Driving 40 LEDs using PORT multiplexing (8x5) (I)
Driving 40 LEDs using PORT multiplexing (8x5) (II)
External Interrupts
Driving Liquid Cristal Displays
End of uC Series
Global Positioning System (GPS)
Introduction to Global Positioning
GPS Receivers
GPS Errors
Differential GPS
Re: Micro-controllers for day-to-day life (Sinhala Medium)
Posted: Fri Apr 30, 2010 8:45 am
I have Read Vidusara News Paper too. It's Very Good Paper and Thank you for This Great Help You are doing for Sinhala People.
Thanks a Lot
Posted: Fri Apr 30, 2010 7:17 pm
by Rksk
Bro,
also i think this post can do something for ROBOT.LK because sri lankans who find about pic in sinhala, can be come to ROBOT.LK and join with it.
thanks.
Posted: Sat Mar 10, 2012 1:40 am
by SemiconductorCat
This is soo great man.Keep writing.
Posted: Sat Mar 10, 2012 2:52 pm
by Nandika
SandunDhammikaPerera wrote:This is soo great man.Keep writing.
Actually Sandun,this artistic are grate explanation of Micro Controller Units.
I think,This article is very important for not only Beginners but also old hands.
But,I'm a Beginner. ;)
I hadn't any fundamental knowledge or qualification for learn about MCU.But,I could get lot of knowledge about MCU fro A to... not Z.about B,C. :yahoo:
1.Introduction to MCU.
2.System of MCU.
3.Coding with Assembly and C.
4.Internal System of PIC(16f84a,16f877).
5.PWM
6.IR Communication
7.AD Convertor
8.Communicate with PC using serial port
9.GPS
10.LCD Controlling
Thanx
Posted: Sat Jun 30, 2012 2:06 am
by Saman
Posted: Sun Jul 01, 2012 9:36 am
Saman wrote:??????? High Speed ??????
https://robot.lk/viewtopic.php?f=18&t=3419
Rep++
Posted: Mon Jul 02, 2012 12:18 am
by Rksk
high speed ?????? high speed? ????? ?????? pdf ??? zip ???? ??? attach ?????? ?????
Posted: Fri Oct 26, 2012 11:37 pm
by Nandika
Logo
Logo
?? ??? WinRar ????? ???? ???? 4share ??? ????? ???..
File size:-27.0 MB
Contents:-85 pdf and one png image
Uploaded date:-10/26/2012
Download Link:- http://www.4shared.com/rar/I18lmaDB/Vidusara_MCU.html
¸.•?•.¸¸.•?•¸Good Luck ¸.•?•.¸¸.•?•¸.•?•.¸¸.•?•¸.•?•.¸¸.•?•¸.•?•.¸¸.•?•.¸
