Windows Live Messenger Connection error!!
Posted: Mon Aug 29, 2011 5:43 pm
by PraveenAlexis
today i downloaded Windows Live Messenger to chat with one of my friend
and then when i log in it says the following error, i searched and i found some trouble shootings but they arnt working
can anyone help me with this issue
Re: Windows Live Messenger Connection error!!
Posted: Mon Aug 29, 2011 6:40 pm
I received this error few years ago after an upgrade to a later version. I then installed an older version and it worked.
Can you try an older version and see whether it gives you the same error?
Posted: Mon Aug 29, 2011 7:14 pm
by PraveenAlexis
i didnt try an old vision, il try and bump this topic
Posted: Mon Aug 29, 2011 8:05 pm
by PraveenAlexis
old version is not working too
i cant even install it
its says i haven't connected to the net
Posted: Mon Aug 29, 2011 9:53 pm
by Herath
Did you attempt repair options in windows live messenger. Seems like some proxy issue. Try googling the error code. 80072efd
Posted: Tue Aug 30, 2011 10:29 pm
by PraveenAlexis
Herath wrote:Did you attempt repair options in windows live messenger. Seems like some proxy issue. Try googling the error code. 80072efd
i did, i did every thing that i can possiblely do, still the same
Posted: Wed Aug 31, 2011 1:03 am
Can you try this one.
Open a run window by clicking start, then run. Now, type the following command and press enter:
regsvr32 softpub.dll Wintrust.dll Initpki.dll Rsaenh.dll Mssip32.dll Cryptdlg.dll
If you use Windows XP you should open another run window after running the previous commands then type the following command:
regsvr32 Dssenh.dll Gpkcsp.dll Slbcsp.dll Sccbase.dll
Posted: Wed Aug 31, 2011 11:04 am
by PraveenAlexis
Initpki.dll
this file failed to load
and the problem still seems the same
and the error msg is "your machine appears to have an invalid ip address"
and im using a airtel dongle
Posted: Wed Aug 31, 2011 6:43 pm
I have installed Windows Live Messenger myself to see whether there is any common problem. It worked like a charm
So I have noway to simulate the issue. How if you try something like Trilian which supports MSN messenger protocol. Also, I heard you can contact your MSN friends through Yahoo messenger now. But I didn't try it myself.
Posted: Wed Aug 31, 2011 7:12 pm
by PraveenAlexis
Neo wrote:I have installed Windows Live Messenger myself to see whether there is any common problem. It worked like a charm
ya sure il try
