Snow sensing helps predict water shortages
Posted: Fri Jun 14, 2013 6:25 am
Melting fast this year (Image: NASA JPL/CalTech)
Precisely measuring supplies of meltwater could help farmers in the US plan what they plant in order to battle a changing climate
"OUR water supply is always under threat." Like most farmers in California's fertile San Joaquin valley, Zachary Sheely is dependent on snowmelt from the Sierra Nevada mountains for his livelihood. But the snows have become sparse and inconsistent, complicating decisions on which crops to grow. "We are getting more and more years in a row with extreme conditions so the risk to our crops is huge," he says.
Help could soon be at hand. A pair of airborne sensors developed by NASA, coupled with on-the-ground smartphone apps, could make the lives of farmers like Sheely a little easier.
Estimates of the volume of snow on a mountain and the meltwater it will produce are usually made manually, so are error-prone. "They go out there with sticks to measure snow depth," Sheely says. This makes planning which crops to grow a nightmare. If Sheely knew water was going to be scarce, he could cut back on thirsty crops like almonds and grapes. "These are huge decisions with huge risks attached for farmers," he says.
To change that, Tom Painter and a team of engineers at NASA's Jet Propulsion Lab (JPL) have equipped a light aircraft with two sensors that can precisely measure the volume of snow present while flying over mountain ranges. A laser-based radar measures the depth and density of the snow, so the amount of water present can be determined, while a spectrometer measures how much sunlight the snow is reflecting and absorbing. This can predict how fast it will melt and run down into the valleys in the summer.
In April, the plane, called the Airborne Snow Observatory, began a three-year series of test flights over two mountain water sources in the US: the Tuolumne river basin in the Sierras and the Uncompahgre river in the Upper Colorado river basin.
Early results look good. The flights allow for accurate mapping of the snow cover and reveal how much meltwater it is expected to generate. Within 24 hours, this information can be supplied to farms and water-using businesses like power stations. The flights – currently operating once a week – are making one thing clear: "Snowpack is going fast this year. It's very, very dry," Painter told New Scientist.
In California, snowpack was only around 17 per cent of its average May volume, according to the California Department of Water Resources in Sacramento. As a result, farmers may only get a fraction of the water they need this summer, says Sheely, who has already decided to leave a tenth of his land fallow.
The situation is equally tense further east, in the basins fed by snow in the Rocky Mountains. "The Colorado river basin has been experiencing drought conditions dating back to 1999," says Anne Castle, assistant secretary for water and science at the US Department of the Interior. "All areas in the basin are struggling with the prospect of permanently reduced supplies, so water managers would welcome earlier, better and more detailed forecasts."
Richard Atwater, executive director of the Southern California Water Committee, says JPL's snowpack maps will result in "better decisions on storing or releasing water behind each dam and reservoir", helping save water for long, hot summers.
Meanwhile, Sheely is being proactive. Working with Colorado-based agri-tech company AgWorld, he has developed an iPad app that helps farmers make the most of drier conditions. He hopes the app will establish a collaborative network in which farmers input and share data on local conditions in a bid to make their irrigation operations more efficient and sustainable. He plans to enable later versions to incorporate the snowmelt predictions made by the Airborne Snow Observatory, plus soil moisture readings from sensors placed in fields – giving the growers an unprecedented picture of their crops' prospects.
Gayle Holman of farming advocacy group Westlands Water District thinks farmers like Sheely are the future. "His apps for advanced irrigation practices enable growers to utilise state-of-the-art water conservation practices," she says. "Growers like Sheely have become part of the solution for water supply reliability."
This article appeared in print under the headline "Fly-bys warn of water shortages"
