Page 1 of 2
Problem with Samsung DVD Writer
Posted: Fri Aug 19, 2011 8:06 pm
Hi
There is a problem with my Samsung DVD writer. I bought it about 6 months ago.
Problem is some times It can't recognize CD DVD or any. But I can see it in My Computer and When I press Eject button tray comes out. And when I insert a CD or DVD windows mouse pointer indicates that there is a CD in the drive but I can't see there is a CD in the drive only normal drive icon can be seen.
So I connected the SATA cable of DVD writer to another port then it worked, then after some days the problem started again. So I removed and replugged the cable again then worked for some more days. Today it started again, And after bending and shaking the cable little it worked again.
I think this is a problem with the cable, So I checked it with multimeter but couldn't find any problem. And this problem comes randomly. So I think it can't find with multimeter because there must be a loose connection or something.
By the way I gave money to a friend of mine to bring me a cable.
Do you think is this the problem?
Re: Problem with Samsung DVD Writer
Posted: Fri Aug 19, 2011 8:18 pm
Yes, cable can probably be the problem. However, if you can check with Ubuntu (I know you have it installed) you can confirm that is a hardware problem.
Posted: Fri Aug 19, 2011 10:03 pm
Neo wrote:Yes, cable can probably be the problem. However, if you can check with Ubuntu (I know you have it installed) you can confirm that is a hardware problem.
Yes I already tried. Same with Ubuntu.
Posted: Fri Aug 19, 2011 11:58 pm
by PraveenAlexis
maybe there is a problem in you sata ports on ur mother board! I had a anoyoing bug with my samsung drive, when i insert a cd or a dvd, the tray omes back again, i have to do it almost 10times to get it stoped auto ejecting
Posted: Sat Aug 20, 2011 1:04 am
by Herath
Samsung is one of my not-recommended brands for HDDs, mobiles and optical drives. :D
I am owning a Asus DRW-1814BL drive. It's really rock-solid. Never had a problem with for 4 years now. One of my friends had that crazy tray problem. The tray comes out suddenly while reading a disc and it is so annoying. :D .
Posted: Sat Aug 20, 2011 3:30 am
Herath wrote:Samsung is one of my not-recommended brands for HDDs, mobiles and optical drives. :D
I have Sony Combo drive and it's about 3 years old and still works almost well :D . It has not recognizing a Blank DVD problem. But it did before.
But even I have Samsung HDD it is almost same as my combo drive and it work well.
Posted: Sat Aug 20, 2011 7:55 am
by PraveenAlexis
i have another drive LG DVD-RW DRIVE, i bought it IN YEAR 2002 still i didnt find any problem with that except its transfer speed is a bit low maybe since its a IDE DRIVE :roll: now i recommend LG STUFF :D BTW MAXTER IS GOOD FOR HDD, I HAD A SAMSUNG 250GB HDD, IDK HOW IT HAPPEND, IT GOT BAD SECTORS ALL OVER, DAMN IT UNFORTUNATELY I HAD WARRENTY,
Posted: Sat Aug 20, 2011 6:33 pm
Changed the cable but still same no luck :(
Its name is Samsung. But in device manager it says this. (I think Samsung and Sharp both make these ODDs together )
TSSTcorp CDDVDW SH-S243D
I even couldn't find the firmware to update my drive.
By the way. I tried cable plugging into 2 port but no luck. Worked one or two times, Then began that error again. I can't figure out what the heck this is :x
Posted: Sat Aug 20, 2011 8:43 pm
Did firmware reinstalling because there is no update for it.
But problem still same. :x
What can I do?
Now I feel to kick this and throw this away. :x I get very mad when I can't find a solution for a very annoying problem :evil:
Posted: Sat Aug 20, 2011 10:55 pm
by PraveenAlexis
1st try lence cleaning
2nd replace with warrenty, ;)
3rd chop it :lol:
