How to Uninstal Prolink H9601c USB Modem Drivers Windows 7
Posted: Fri Jun 17, 2011 7:36 pm
Hello
I got a New Problem
My Router's Power Adapter is Broken and My Other Power packs' Power isn't Enough for the Router.
So I tried to install my Modem again. Last time When I try to Uninstall it last time it didn't succeed(Said Can't find /Key and bla bla ...) So I Manually deleted the files and removed Registry Entries
And This time I tried to install it again but it says, Modem is Already installed remove it and then Install. So I searched C drive for files and then deleted the files. But Still same. Still say it's already installed but there is no any file is left that i can see.
So I had to take my Uncle's Suntel CDMA Phone's Power Adapter and Connect my Router's Power Adapter's Cable by Sticking Sellotapes :D. I will use this until I buy another Power Adapter. Which is 12V 500mA one. My Other ones' Current weren't Enough. They were 300mA.
My Question is How to Install Modem Drivers Again? Because I am thinking to use the Modem until I buy another Power Adapter.
Re: How to Uninstal Prolink H9601c USB Modem Drivers Windows 7
Posted: Fri Jun 17, 2011 11:35 pm
Posted: Sat Jun 18, 2011 5:05 am
Yes, I'll try those.
Posted: Sat Jun 18, 2011 9:49 pm
They Didn't work Friend.
So I downloaded Unknown Device Finder software and then Searched my Modems Driver then I got this page.
http://www.dlink.com.au/tech/drivers/fi ... dsl200.htm
Using its Remover tool I was able to remove the driver and Reinstall it again.
First time I when used the tool, It didn't remove it although it said it did but actually not :D So i ran it again then it worked.
Then reinstalled Drivers again and working fine.
I will use Modem until i find another Power Adapter.
Posted: Sun Jun 19, 2011 9:55 am
Actually My Modem is D-Link DSL200 One. Only Name and Appearance is Different :D
That Means I could be able to work with this Linux (Actually Ubuntu :) )
Posted: Fri Nov 04, 2011 6:39 pm
by Rrrox
U r modem is Dlink or Prolink??? :?
If it is Prolink h9601 model can you explain how you uninstalled it, because I'm ended up with much trouble with the modem,
I cant find the driver software but it keeps telling me it is installed...
I tried the above removing tool but didnt worked.
Anyway thnk U.
:D
Posted: Fri Nov 04, 2011 7:22 pm
My modem is a Prolink h9601c one.
But by searching drivers with Unknown Device Finder, I've found out that it is really a Dlink one.
I said all the info about how I was able to unstall it. But in another day I wanted to remove the drivers again after an installation and that time the tool didn't work as same as yours, but I tried again and again then it worked. I don't know why sometimes it doesn't unstall the driver.
Posted: Fri Nov 04, 2011 7:25 pm
by Rrrox
Oh! I didnt get it first and confused with your last comment!
Anyway after REBOOTING FOR THE SECOND TIME it was nothing.
Without your discovery ILL throw that modem to DusTBin
Ela thnx it was a lot a help...
Posted: Fri Nov 04, 2011 7:44 pm
You are welcome :)
