This Thread is Related to this Thread https://robot.lk/viewtopic.php?f=13&t=2430
My New Router I am using now, Sometimes when i watch online live streams, Suddenly Internet connection goes. But all Router's Light working but can't connect to the net. And after little time Network indicator of Windows 7 shows a Yellow symbol and says no internet access.
When this was happening, I tried to log in to router's admin panel but it was only loading but didn't succeed. Then I restarted the Router then it worked. This happened 2 times today and every time i restarted the router.
But Only when watching Videos at other times it's working well.
Our Phone line sometimes has a Bad sound. I mean like a loose connection. Is this could be the Problem?
Or Is this because of using via USB? But I suspect this.Since If modem worked well there can't be a problem. But when i was using modem in past days it disconnected a lot. Since I feel phone line's problem caused this. (Our Phone line Damaged too Due to the Lightnings at past days. After repairing it there are still problems )
If this is a Problem with the Router Will it be solved by Upgrading the Firmware ? But I can't do it until i buy a Network Card since My Router only supports upgrades via LAN.
Problem with the New Router
Re: Problem with the New Router
Of cause this will disrupt the ADSL connection between your router and the SLT switch. SLT also refresh the IPs evry 5 hours or so. At that time also, you will be disconnected for at least few seconds.Our Phone line sometimes has a Bad sound. I mean like a loose connection. Is this could be the Problem?
No I don't think so.Or Is this because of using via USB?
You can complain them again if you don't have the perfect line quality.After repairing it there are still problems
I have seen some routers that only support Firmware upgrade through LAN. If that is the case, yes, you need to wait till you get a Ethernet card.If this is a Problem with the Router Will it be solved by Upgrading the Firmware ? But I can't do it until i buy a Network Card since My Router only supports upgrades via LAN.
Thanks Friend. I think the Phone Line is the Problem.
If you get unidentified network in network list, update your windows and use static IP for your computer. I had these kind of problems and solved them later. Windows event logs helped a lot to figure out some problems.
Hey Nipuna, it seems our best Support Member is back in to business
Welcome Herath after a long time !!!
We really missed you.
Yes. We missed Him Very Much.
Welcome Back Friend.
