Page 1 of 2
Sony Ericsson P1i Firmware Flash
Posted: Wed Feb 17, 2010 4:43 pm
Please tell me how to Do a Complete Sony Ericsson P1i Firmware Flash? Please Tell me Step by Step.
Re: Sony Ericsson P1i Firmware Flash
Posted: Wed Feb 17, 2010 6:17 pm
I did this for Sony Ericsson W850i few years back through the data cable with the use of a software that I found by Googling for hours. Try Googling a bit...
Posted: Wed Feb 17, 2010 6:22 pm
Neo wrote:I did this for Sony Ericsson W850i few years back through the data cable with the use of a software that I found by Googling for hours. Try Googling a bit...
Thanks.
but i Tried That's why i decided to ask here.
Posted: Thu Feb 18, 2010 6:26 pm
Please Someone Help ME.
Posted: Thu Feb 18, 2010 8:12 pm
One person has reported
this as working. So you would give it a try.
Get update service from
Sony site.
Posted: Thu Feb 18, 2010 8:20 pm
Neo wrote:One person has reported
Sony site.
Thanks Buddy I tried this But No use. Please say me another
This is the Problem of my Phone.
My phone always restarts saying
"the phone has restarted in order to improve it's performance"
But some times My phone works. I tried Sony Ericsson Update service But no result.
Posted: Thu Feb 18, 2010 8:56 pm
That's the best one I found by searching. I understand your problem, it seems that your phone is either having a firmware bug or a little hardware problem that make it misunderstand something. As a firmware developer, these are quite usual things for me. However the point is, it will be not easy to find the real problem for you. The only thing you can try is the firmware update. If that is not working for you, you should check for any viewable hardware error by showing it to a knowledgeable guy (probably at Siedles (Sony Agents)).
Also try to do a system restore from menu. That sometimes sort out simple problems.
Posted: Thu Feb 18, 2010 9:16 pm
Neo wrote:That's the best one I found by searching. I understand your problem, it seems that your phone is either having a firmware bug or a little hardware problem that make it misunderstand something. As a firmware developer, these are quite usual things for me. However the point is, it will be not easy to find the real problem for you. The only thing you can try is the firmware update. If that is not working for you, you should check for any viewable hardware error by showing it to a knowledgeable guy (probably at Siedles (Sony Agents)).
What is Siedles Please tell me.
Posted: Thu Feb 18, 2010 9:34 pm
Posted: Mon Jul 26, 2010 10:39 am
by Rksk
