How to access Windows Registry from Java
Posted: Fri Nov 27, 2009 3:20 am
Here is a easy way to access Windows registry from Java the easy way via API . Otherwise you should be writing JNI code to access registry which is a demanding job for a newbie.
There are certain important functionalities in Win32 API like getting Window handles, Spawning new process, killing process, Send Keystrokes, Tweaking Registry, Logging lots and lots more.
Follow the listed steps:
Example 1: Displaying a message box
Example 2: Accessing the registry
- JNIRegistry
- JWinAPI
JWinAPI is even more versatile and Powerful because it is not only allowing to access Registry from java but also allows you to use almost all Windows API in Java Directly just by including this API in your Project.
- Visit this page
- Download copy of JWinAPI
- Install the using setup
- Include JWinAPI.jar in your Project Library.
- Done!
java -jar JWinAPI.jar
WinAPI wapi = new JWinAPI();
wapi.doMessageBox("JWinAPI DLL has been loaded successfully!",
"JWinAPI", MBConstants.MB_OK + MBConstants.MB_ICONASTERISK );
// write an int value
wapi.doWriteToRegistry(REGConstants.HKEY_CURRENT_USER,
"Software\\ROBOT.LK\\regsample",
"javaINTValue", REGConstants.REG_DWORD, new Integer(876543) ) ;
