Java Programming History Part-9
Posted: Wed Apr 25, 2012 10:17 pm
Java Naming and Directory Interface
The Java Naming and Directory Interface (JNDI) is a Java API for a directory service that allows Java software clients to discover and look up data and objects via a name. Like all Java APIs that interface with host systems, JNDI is independent of the underlying implementation. Additionally, it specifies a service provider interface (SPI) that allows directory service implementations to be plugged into the framework. It may make use of a server, a flat file, or a database; the choice is up to the vendor.Background
The JNDI API is used by the Java RMI and Java EE APIs to look up objects in a network. Jini has its own lookup service and does not use the JNDI API.The API provides:
A mechanism to bind an object to a name
A directory lookup interface that allows general queries
An event interface that allows clients to determine when directory entries have been modified
LDAP extensions to support the additional capabilities of an LDAP service
The SPI portion allows support for practically any kind of naming or directory service including:
1. LDAP
2. DNS
3. NIS
4. CORBA name service
5. File system
The JNDI specification was first released by Sun Microsystems on March 10, 1997. As of 2006, the current version is JNDI 1.2.
Basic lookup
JNDI (Java Naming and Directory Interface) organizes its names into a hierarchy. A name can be any string such as "com.mydomain.ejb.MyBean". A name can also be an object that supports the Name interface, however a string is the most common way to name an object. A name is bound to an object in the directory by storing either the object or a reference to the object in the directory service identified by the name.The JNDI API defines a context that specifies where to look for an object. The initial context is typically used as a starting point.
In the simplest case, an initial context must be created using the specific implementation and extra parameters required by the implementation. The initial context will be used to look up a name. The initial context is analogous to the root or top of a directory tree for a file system. Below is an example of creating an initial context:
Hashtable contextArgs = new Hashtable();
// First you must specify the context factory.
// This is how you choose between jboss implementation
// vs. an implementation from Sun or other vendors.
contextArgs.put( Context.INITIAL_CONTEXT_FACTORY, "com.jndiprovider.TheirContextFactory" );
// The next argument is the URL specifying where the data store is:
contextArgs.put( Context.PROVIDER_URL, "jndiprovider-database" );
// (You may also have to provide security credentials)
// Next you create the initial context
Context myCurrentContext = new InitialContext(contextArgs);
MyBean myBean = (MyBean) myCurrentContext.lookup("com.mydomain.MyBean");
The Context object can also be configured by adding jndi.properties file in classpath containing initial context factory class name and provider URL. The above code will be reduced as shown below:
//just need to create initial context object, it will try to read jndi.properties file from //classpath.
Context myCurrentContext = new InitialContext();
Searching
Attributes may be attached to special entries called directories. Directories enable searching for objects by their associated attributes. Directories are a type of context; they restrict the name space much like a directory structure on a file system does.N:B:-Coming soon more Topic
