Java MP3 Player Source Code
Posted: Wed Sep 21, 2011 9:10 am
Description:
This example shows how to create a MP3 Player in Java. It uses JMF (Java Media Framework) to do this.
Example Code:
Following code plays MP3 files. Please make sure you have jmf.jar file in your classpath.
import java.awt.BorderLayout;
import java.awt.Color;
import java.awt.Component;
import java.awt.Container;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.event.WindowAdapter;
import java.awt.event.WindowEvent;
import java.io.File;
import javax.media.ControllerEvent;
import javax.media.ControllerListener;
import javax.media.Manager;
import javax.media.Player;
import javax.media.RealizeCompleteEvent;
import javax.swing.JButton;
import javax.swing.JFileChooser;
import javax.swing.JFrame;
import javax.swing.JOptionPane;
public class MediaPlayerDemo extends JFrame {
    private Player player;
    private File file;
    public MediaPlayerDemo() {
        super("Demonstrating the Java Media Player");
        JButton openFile = new JButton("Open file to play");
        openFile.addActionListener(new ActionListener() {
            public void actionPerformed(ActionEvent e) {
                openFile();
                createPlayer();
        getContentPane().add(openFile, BorderLayout.NORTH);
        setSize(300, 300);
        show();
    private void openFile() {
        JFileChooser fileChooser = new JFileChooser();
        fileChooser.setFileSelectionMode(JFileChooser.FILES_ONLY);
        int result = fileChooser.showOpenDialog(this);
        // user clicked Cancel button on dialog
        if (result == JFileChooser.CANCEL_OPTION)
            file = null;
        else
            file = fileChooser.getSelectedFile();
    private void createPlayer() {
        if (file == null)
            return;
        removePreviousPlayer();
        try {
            // create a new player and add listener
            player = Manager.createPlayer(file.toURL());
            player.addControllerListener(new EventHandler());
            player.start(); // start player
        } catch (Exception e) {
            JOptionPane.showMessageDialog(this, "Invalid file or location",
                    "Error loading file", JOptionPane.ERROR_MESSAGE);
    private void removePreviousPlayer() {
        if (player == null)
            return;
        player.close();
        Component visual = player.getVisualComponent();
        Component control = player.getControlPanelComponent();
        Container c = getContentPane();
        if (visual != null)
            c.remove(visual);
        if (control != null)
            c.remove(control);
    public static void main(String args[]) {
        MediaPlayerDemo app = new MediaPlayerDemo();
        app.addWindowListener(new WindowAdapter() {
            public void windowClosing(WindowEvent e) {
                System.exit(0);
    // inner class to handler events from media player
    private class EventHandler implements ControllerListener {
        public void controllerUpdate(ControllerEvent e) {
            if (e instanceof RealizeCompleteEvent) {
                c.setBackground(new Color(255, 255, 204));
                // load Visual and Control components if they exist
                Component visualComponent = player.getVisualComponent();
                if (visualComponent != null)
                    c.add(visualComponent, BorderLayout.CENTER);
                Component controlsComponent = player.getControlPanelComponent();
                if (controlsComponent != null)
                    c.add(controlsComponent, BorderLayout.SOUTH);
                c.doLayout();
