Page 1 of 3
18 errors in this OMG
Posted: Sat Aug 07, 2010 8:59 pm
by Face
import java.util.Scanner;
/** made by gayan bandara.
date 07.08.2010
to make a calc*/
class Gayan_calculator{
	public static void list(){
	System.out.println("press + for Add numbers");
	System.out.println("press - for Substract numbers");
	System.out.println("press * for Multily numbers");
	System.out.println("press / for Divide numbers");
	public static void main(){
		Scanner input=new Scanner(System.in);
		int selection=0;
		list();
		System.out.println("\npress option from the list");
		System.out.println("--------------------------");
		selection = input.nextint();
		if(selection==+||selection==-||selection==*||selection==\){
		System.out.println("Please enter your first number.");
                int num1 = input.nextInt();
                System.out.println("Please enter your second number.");
                int num2 = input.nextInt();
		if(selection==+)
			int x = num1 + num2 ;
			System.out.println(num1+" + "+num2+"="+x);
			System.out.println("-----------------------------------");
		if(selection==-)
			int x = num1 - num2 ;
			System.out.println(num1+" - "+num2+"="+x);
			System.out.println("-----------------------");
		if(selection==*)
			int x = num1 * num2 ;
			System.out.println(num1+" * "+num2+"="+x);
                if(selection==/)
			int x = num1 / num2 ;
			System.out.println(num1+" / "+num2+"="+x);
			}else{
				System.out.println("Can't recognize your option");
I found 18 errors when I compile this in a java editor.these are the errors I found
>javac Gayan_calculator.java
Gayan_calculator.java:29: illegal start of expression
Gayan_calculator.java:29: illegal character: \92
Gayan_calculator.java:29: ';' expected
Gayan_calculator.java:37: illegal start of expression
		if(selection==+)
Gayan_calculator.java:44: illegal start of expression
		if(selection==-)
Gayan_calculator.java:51: illegal start of expression
		if(selection==*)
		if(selection==*)
Gayan_calculator.java:57: illegal start of expression
                if(selection==/)
                if(selection==/)
Gayan_calculator.java:65: illegal start of type
			}else{
Gayan_calculator.java:65: ';' expected
			}else{
Gayan_calculator.java:66: <identifier> expected
Gayan_calculator.java:66: illegal start of type
Gayan_calculator.java:69: class, interface, or enum expected
18 errors
>Exit code: 1
I think that My selection has the main problem.can't I use + - * / as options to select..?can you please help me on this BIG problem....This is the biggest code I wrote in my life... :D
Re: 18 errors in this OMG
Posted: Sun Aug 08, 2010 12:45 am
Here +, -, etc... are operators. They do not represent an integer value.
The best thing you can do is, define "selection" as char and change all your "if"s as selection == '+' and so on.
Let me know if you get further errors.
Posted: Sun Aug 08, 2010 8:21 am
by Face
wow...I change according to you idea..it works..now only one error
    date 07.08.2010
    to make a calc*/
          char selection=0;
          list();
          if(selection=='+'||selection=='-'||selection=='*'||selection=='/'){
          if(selection=='+')
          if(selection=='-')
          if(selection=='*')
                    if(selection=='/')
             }else{
this is the error i got in editor..
Gayan_calculator.java:71: class, interface, or enum expected
    }sub.nul.nul.nul.nul.nul.nul.nul.nul.nul.
Posted: Sun Aug 08, 2010 9:27 am
There was an extra bracket after the last else. You missed it as the indents are not correctly maintained. I corrected the indents as below and removed the extra curly bracket.
date 07.08.2010
to make a calc*/
      Scanner input = new Scanner(System.in);
      char selection = 0;
      list();
      if(selection == '+' || selection == '-' || selection == '*' || selection == '/'){
				if(selection == '+'){
				if(selection == '-'){
				if(selection == '*'){
				if(selection == '/'){
			else{
Posted: Sun Aug 08, 2010 12:44 pm
by Face
still have an error...
Gayan_calculator.java:25: cannot find symbol
symbol  : method nextint()
1 error
>Exit code: 1
I think that is should be like this
selection = input.nextchar();
because we changed the variable type....right?
Posted: Sun Aug 08, 2010 12:48 pm
by Face
OMG........It has the same error...again...
I changed that like this...
    date 07.08.2010
    to make a calc*/
          char selection = 0;
          list();
             else{
This is the new error I got...
symbol  : method nextchar()
1 error
>Exit code: 1
Posted: Mon Aug 09, 2010 10:26 am
the problem is nextint which should be changed to nextInt (notice the capital 'I').
Java is a case sensitive language just as C/C++ so those things need to be considered carefully.
Posted: Mon Aug 09, 2010 7:28 pm
by Face
oh BRO I corrected it now..then there are no compiling errors..But it doesn't work...
    date 07.08.2010
    to make a calc*/
          int selection = 0;
          list();
          selection = input.nextInt();
             else{
This is the massage I got when trying to run the program..
>java -cp . Gayan_calculator
java.lang.NoSuchMethodError: main
Exception in thread "main" >Exit code: 1
Posted: Mon Aug 09, 2010 9:23 pm
by Face
        date 07.08.2010
        to make a calc*/
           public static void list(String args[]){
              int selection = 0;
              list();
                 else{
Now It runs...But Half.........:(
Posted: Tue Aug 10, 2010 11:06 am
by Herath
Half means?.
Normally, the argument list is a parameter of the main method.
So,
public static void main(String[] args)
