Converting Between Binary and Decimal in C#
Posted: Tue Nov 10, 2009 5:07 pm
by Cyclops
The following two source code listings show how to write a crude but effective console mode application for converting a number, either from binary to decimal, or from decimal to binary. Note: you pass in the decimal number or the binary string as a parameter when typing the program's name at a command prompt.
From Decimal to Binary...
using System;
class Program{
   static void Main(string[] args){
      try{
  int i = (int)Convert.ToInt64(args[0]);
         Console.WriteLine("\n{0} converted to Binary is {1}\n",i,ToBinary(i));
      }catch(Exception e){
         Console.WriteLine("\n{0}\n",e.Message);
   }//end Main
  public static string ToBinary(Int64 Decimal)
   // Declare a few variables we're going to need
   Int64 BinaryHolder;
   char[] BinaryArray;
   string BinaryResult = "";
   while (Decimal > 0)
    BinaryHolder = Decimal % 2;
    BinaryResult += BinaryHolder;
    Decimal = Decimal / 2;
   // The algoritm gives us the binary number in reverse order (mirrored)
   // We store it in an array so that we can reverse it back to normal
   BinaryArray = BinaryResult.ToCharArray();
   Array.Reverse(BinaryArray);
   BinaryResult = new string(BinaryArray);
   return BinaryResult;
}//end class Program
From Binary to Decimal...
using System;
class Program{
      try{
         int i = ToDecimal(args[0]);
         Console.WriteLine("\n{0} converted to Decimal is {1}",args[0],i);
   }//end Main
                public static int ToDecimal(string bin)
                    long l = Convert.ToInt64(bin,2);
                    int i = (int)l;
                    return i;
