ANY BIGINERS TO PIC's
Embedded Systems Topics
RAT16F88
Post by RAT16F88 » Sun Nov 21, 2010 12:50 am
Go ahead & follow my blog <link removed> you'll find the circuit diagram to build a programmer then
download MPlab too , Better Start with a Simple PIC like PIC 16f84a thts how I started
Good luck :) :) :) :)
also follow the datasheet of 16f84a care fully I ll Update u for the 1st project
U need a bit of common sense thats all (i assume u've burnt ur fingers with a soldering Iron :mrgreen: -i mean ur not new to tronic :geek: s)
Reason: Link removed by admin
RAT16F88
Re: ANY BIGINERS TO PIC's
Post by RAT16F88 » Sun Nov 21, 2010 2:14 pm
Please be kind to leave a comment thats a big enthusiasm :( :( :(
Post by Neo » Sun Nov 21, 2010 4:53 pm
Only submit questions here. We don't allow anybody to do any type of marketing in technical topics :)
However, you can brief about your site and add a link under Member Area -> Member Advertising.
ROBOT.LK is backed with a set of qualified engineers so hope you don't waste their time on submitting non-question posts here. Hope you'll understand ;)
We have a separate section for Microcontrollers.
See Engineering ‹ Embedded Processors & Programming ‹ Microcontrollers
See Multi PIC programmer to make a programming unit.
See my article How to start with Microcontrollers which has a complete list of steps to begin with micros.
You may also see following 16F84 experiments.
16F84 Sample LED Circuit Diagram
Musical DoorBell with PIC16F84A
PIC Traffic Lights Controller with PIC16F84A
Be with us and get the full use of it..... Good luck!!!
RAT16F88
Post by RAT16F88 » Mon Nov 22, 2010 2:17 am
:oops: :oops: :oops: :oops:
Oh I'm sorry I thought It would Be really Simple for any biginner to swallow & follow Thts why I put up all my work I done when I was In 10th Grade On a blog & Put it here 'sorry again I 'm new here ,Thank U for Informing ME, Sorry Again :( :( :(
Post by Neo » Mon Nov 22, 2010 2:25 am
No problem... please enjoy the forum :)
RAT16F88
Post by RAT16F88 » Mon Nov 22, 2010 2:51 am
THANKS I WAS So DWN SEEING IT Thanks for upliftment
Post by Neo » Mon Nov 22, 2010 9:35 am
If you read Terms of use carefully, you wouldn't have ended up with unnecessary unpleasantness. See point (7).
mudit123akg
Corporal
Corporal
Post by mudit123akg » Fri Mar 04, 2011 12:01 pm
hii
muti pic programmer is not working pls help
Post by Saman » Fri Mar 04, 2011 12:27 pm
It works perfectly. We make them locally and as said in the previous post let me have your address then I'll let you know the payment instructions.
Return to “Embedded Systems”
