Delete a file from code
Jane
Corporal
Corporal
Post by Jane » Sun Jul 19, 2009 9:46 pm
Hi,
Is it possible to delete a file from C++ without using Win API function.
Jane
Re: Delete a file from code
Post by Neo » Tue Jul 21, 2009 3:24 pm
int remove ( const char * filename );
If the file is successfully deleted, a zero value is returned.
On failure, a nonzero value is reurned and the errno variable is set to the corresponding error code.
Return to “C/C++ Programming”
