session_start();
if(!isset($_SESSION['SESS_LOGIN']) || $_SESSION['SESS_TYPE'] !='admin')// if session variable "login" does not exist.
echo '<script language="javascript">';
echo 'alert("Please login as ADMINISTRATOR to edit a user");';
echo ' window.location.replace("login-form.php");';
echo '</script>';
//header("location:login-form.php"); // Re-direct to login-form.php
else
include("config.php");
$id = mysql_real_escape_string($_POST['id']);
$login = mysql_real_escape_string($_POST['login']);
$password = mysql_real_escape_string($_POST['password']);
$type = mysql_real_escape_string($_POST['type']);
$qry_edit = " UPDATE members SET login='$login', password='$password', type='$type' WHERE id='$id' ";
$count = mysql_query("SELECT COUNT(id) FROM members WHERE id='$id'");
if(mysql_num_rows($count)==1)
if($result=mysql_query($qry_edit))
//or die(mysql_error());
/*echo '<script language="javascript">';
echo 'alert("you have successfully edited one user !" );';
// echo 'window.setTimeout("window.location.replace('adduser.php');",20);';
//echo 'window.setTimeout("window.location.replace('adduser.php'),20");';
echo '</script>';*/
header("Location: view_all_user.php");
else
echo "<br><font color=red size=+1 >Problem in editing !</font>" ;
echo "ERROR - unable to save new username and password!<br>";
$SQLError = "SQL ERROR: ".mysql_errno().". ".mysql_error()."<BR><BR>";
echo "$SQLError";
mysql_close();
//echo "<br><font color=green size=+1 >you have successfully edited one user ! <br>[ username = $login ] </font>" ;
else
echo "<br><font color=red size=+1 >No id !</font>" ;
