How to Add/Remove HTML elements dynamically with Javascript
Web programming topics
Post by Neo » Sat Mar 06, 2010 1:00 pm
In the following article, I’m going to show you how you can dynamically create HTML elements with content wrapped within them according to the DOM2 specification. Those who have a GMail account probably recognize its similarity to the attachment feature when composing new email. Since Gmail’s javascript seems to be hidden… or scrambled… or… whatever they did to it, I was left in the dark trying to figure this one out on my own.
First of all, the (x)html is real simple.
xHTML Snippet
<input type="hidden" value="0" id="theValue" />
<p><a href="javascript:;" onclick="addElement();">Add Some Elements</a></p>
<div id="myDiv"> </div>
The hidden input element simply gives you a chance to dynamically call a number you could start with. This, for instance could be set with PHP or ASP. The onclick event handler is used to call the function. Lastly, the div element is set and ready to receive some children appended unto itself.
Now the JS functions
addElement JavaScript Function
function addElement() {
       var ni = document.getElementById('myDiv');
       var numi = document.getElementById('theValue');
       var num = (document.getElementById('theValue').value -1)+ 2;
       numi.value = num;
       var newdiv = document.createElement('div');
       var divIdName = 'my'+num+'Div';
       newdiv.setAttribute('id',divIdName);
       newdiv.innerHTML = 'Element Number '+num+' has been added! <a href=\'#\' onclick=\'removeElement('+divIdName+')\'>Remove the div "'+divIdName+'"</a>';
       ni.appendChild(newdiv);
removeElement JavaScript Function
function removeElement(divNum) {
       var d = document.getElementById('myDiv');
       var olddiv = document.getElementById(divNum);
       d.removeChild(olddiv);
The addElement function sets a variable by grabbing the element of which we will append a child node to. So in this case, we use the classic getElementById method to track it down. We of course supply the empty ‘myDiv’.
The next three lines basically grab the value of the hidden input element and give your function a starting number to begin with. Then each time the function is called, your value is incremented. This is important for when you need to remove elements, since you’ll need unique id’s.
You’ll notice next the createElement is used to… well… make a new div element. But wait, it needs an id. Thus, we use the setAttribute method to append an id and a value to it. At this point, we have the uniquely named divIdName and we will plug that into the equation for our newdiv object.
Now you’re ready for some content to put inside your dynamic div element using the innerHTML property. And this is when it gets fun. Within your HTML supplied in the innerHTML of the dynamically created div element, you need to provide a link to remove itself. After all, that’s the point of this whole thing, right? It wouldn’t be flexible if all we could do is only add and not remove.
So, a link is put inside with an event handler that calls the function removeElement. Great. Simple enough. Let’s move onto that function.
Okay, now that is easy. First off, it grabs the same parent div element by using getElementById and stores it in a variable. We then get the element to which we passed in as an argument to the function (which was created from the addEvent function), and we store that in another variable.
Return to “Web programming”
