How to access Plesk database?
Linux OS Topics
Post by Saman » Thu Mar 22, 2012 1:02 am
Plesk database is named as psa and stored in the same MySQL server. There are some situations where you need to manually change the settings especially after an update of Plesk panel which ends up with errors due to bugs in update script.
Here is how you could access it.
mysql -uadmin -p`cat /etc/psa/.psa.shadow`
You will be connected to the Mysql server. To use psa database, execute following command.
mysql> use psa;
To view all the psa database tables:
mysql> show tables;
Return to “Linux”
