Experts,
I need to know What are the Shift registers which I can Buy frm Pettah .
regards,
Shift Registers
Re: Shift Registers
Dear Friend ,
I am not sure what are available in Pettah now regarding shift register IC's. But I am quite sure ,there should shift register IC's. (Specially 74 series ICs)
Regards
Regards
Re: Shift Registers
Is it 74HC595
Any way thanku Magneto
Re: Shift Registers
As Magneto stated, 74 series has several TTL shift registers. Have a look at 7400 series integrated circuits list. It is essential to have a brief knowledge on 74 series ICs.
These TTL ICs are available in Pettah.
7491 - 8-bit Shift Register, Serial In, Serial Out, Gated Input
74164 - 8-bit Parallel-Out Serial Shift Register with Asynchronous Clear
There are several CMOS ICs available too. If you use them you will need to put some extra caps to cut of stray and use buffers (sometimes) since output power handling capacity is low in CMOS. If you need to know the availability on CMOS ICs, I'll check tomorrow for you.
We also import electronic parts mostly micros and DSPs in large quantities. However the availability depends on present market trends. If you are buying more items, we can definitely give you a very good price. You can submit your requirement under "Project Assistance" and we can quote on that. (Magneto is the in-charge of that.. I think you already know him).
Re: Shift Registers
Wow sounds cool thankU expert Saman
I'm not producing things Industrially just experimenting things
Thank you for your cooperation
Any way is there a way of paying & receiving parts from you via Mail
Re: Shift Registers
Of cause yes... you can discuss that with Magneto who is handling that.
Re: Shift Registers
Whoops Ideal thanksSaman wrote:Of cause yes... you can discuss that with Magneto who is handling that.
