This example shows how to create a MP3 Player in Java. It uses JMF (Java Media Framework) to do this.
Example Code:
Following code plays MP3 files. Please make sure you have jmf.jar file in your classpath.
import java.awt.BorderLayout;
import java.awt.Color;
import java.awt.Component;
import java.awt.Container;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.event.WindowAdapter;
import java.awt.event.WindowEvent;
import java.io.File;
import javax.media.ControllerEvent;
import javax.media.ControllerListener;
import javax.media.Manager;
import javax.media.Player;
import javax.media.RealizeCompleteEvent;
import javax.swing.JButton;
import javax.swing.JFileChooser;
import javax.swing.JFrame;
import javax.swing.JOptionPane;
public class MediaPlayerDemo extends JFrame {
private Player player;
private File file;
public MediaPlayerDemo() {
super("Demonstrating the Java Media Player");
JButton openFile = new JButton("Open file to play");
openFile.addActionListener(new ActionListener() {
public void actionPerformed(ActionEvent e) {
openFile();
createPlayer();
getContentPane().add(openFile, BorderLayout.NORTH);
setSize(300, 300);
show();
private void openFile() {
JFileChooser fileChooser = new JFileChooser();
fileChooser.setFileSelectionMode(JFileChooser.FILES_ONLY);
int result = fileChooser.showOpenDialog(this);
// user clicked Cancel button on dialog
if (result == JFileChooser.CANCEL_OPTION)
file = null;
else
file = fileChooser.getSelectedFile();
private void createPlayer() {
if (file == null)
return;
removePreviousPlayer();
try {
// create a new player and add listener
player = Manager.createPlayer(file.toURL());
player.addControllerListener(new EventHandler());
player.start(); // start player
} catch (Exception e) {
JOptionPane.showMessageDialog(this, "Invalid file or location",
"Error loading file", JOptionPane.ERROR_MESSAGE);
private void removePreviousPlayer() {
if (player == null)
return;
player.close();
Component visual = player.getVisualComponent();
Component control = player.getControlPanelComponent();
Container c = getContentPane();
if (visual != null)
c.remove(visual);
if (control != null)
c.remove(control);
public static void main(String args[]) {
MediaPlayerDemo app = new MediaPlayerDemo();
app.addWindowListener(new WindowAdapter() {
public void windowClosing(WindowEvent e) {
System.exit(0);
// inner class to handler events from media player
private class EventHandler implements ControllerListener {
public void controllerUpdate(ControllerEvent e) {
if (e instanceof RealizeCompleteEvent) {
c.setBackground(new Color(255, 255, 204));
// load Visual and Control components if they exist
Component visualComponent = player.getVisualComponent();
if (visualComponent != null)
c.add(visualComponent, BorderLayout.CENTER);
Component controlsComponent = player.getControlPanelComponent();
if (controlsComponent != null)
c.add(controlsComponent, BorderLayout.SOUTH);
c.doLayout();
