Java adding program
Java programming topics
Re: Java adding program
Post by Face » Sun May 01, 2011 7:01 am
Ahhh thanks for the help.I will re install it & try. :) I can run it with NetBeams.But I can't run it with out Netbeans.
I install it & then i could see it on open with dialog box.
But When I try to run .jar file.It open sudden & get close.NIPUNA did you test it.?Can you please tell me how it work & how to test it ? (Think that I can't test my own code :) )
Post by Nipuna » Sun May 01, 2011 9:13 am
I Just Double Clicked the .jar file and it worked well :)
Post by Face » Sun May 01, 2011 11:31 am
BRo in my PC it don't work like this.Send me a msg when you are online.I wanna talk & get solved this problem>!!!
See I add another program made just now.!
Post by Neo » Sun May 01, 2011 1:57 pm
Can you download and install JRE. You could download it directly from Oracle using this link. It's 15.8 MB.
http://download.oracle.com/otn-pub/java ... s-i586.exe
I'm sure this will sort out your problem.
Post by Face » Sun May 01, 2011 2:33 pm
NEo I tried that.But Still got the same problem.When I double click the .jar file.Command prompt displays & suddenly get lost.
But I can test the program with NetBeans.What should I do with this?
Post by Nipuna » Sun May 01, 2011 4:43 pm
I found a Solution here it is
http://stackoverflow.com/questions/3546 ... uble-click
It has a Little Program Installing it might Help :)
Here is that Link
http://www.softpedia.com/get/Others/Mis ... rfix.shtml
Post by Face » Sun May 01, 2011 6:15 pm
NIPUNA it worked well..Thanks Bro
Post by Nipuna » Sun May 01, 2011 8:16 pm
You're Welcome Mate :)
Return to “Java Programming”
