In order to use it you must add the following line to your .htaccess file. DO NOT use the full URL to the error page, use the relative path as done in the example below.
ErrorDocument 404 /404.php
Assuming the script below is named 404.php and placed in your htdocs directory.
This script can send an email and/or make an entry in a log file
There are two variables below - one for an email address and one for a log file
Set both vraiables to the values you want to use
If you do not want either an email or log entry, comment out the respective line
For example, if you do not want an email sent, put a // in front of the $emailAddress line - same for the $logFile line
$logFile = $_SERVER['DOCUMENT_ROOT'].'/404.log'; // full path to your log file - you should create an empty starter file if you use logging
$emailAddress = "[email protected]"; // set to your email address
putenv('TZ=EST5EDT'); // set to your time zone
// change nothing below this line
if (isset($emailAddress)) {
$message = "Time of the error: ".date(" F d h:ia")."\n\n";
$message .= "Browser: ".$_SERVER['HTTP_USER_AGENT']."\n\n";
$message .= "Page Requested: ".$_SERVER['HTTP_HOST'].$_SERVER['REQUEST_URI']."\n\n";
$message .= "Referer: ".$_SERVER['HTTP_REFERER']."\n\n";
$message .= "IP Address: ".$_SERVER['REMOTE_ADDR']."\n\n";
$message .= "Hostname: ".gethostbyaddr($_SERVER['REMOTE_ADDR'])."\n\n";
mail($emailAddress,"404 Error", $message,"From: Website <>");
if (isset($logFile)) {
$logData = "404||".$_SERVER['HTTP_HOST'].$_SERVER['REQUEST_URI']."||".$_SERVER['REMOTE_ADDR']."||".date('Y-m-d H:i:s')."\r\n";
@file_put_contents($logFile,$logData,FILE_APPEND|LOCK_EX);
header("HTTP/1.0 404 Not Found");
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en">
<head>
<meta http-equiv="Content-Language" content="en-us" />
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>404 - request not found</title>
<style type="text/css">
body { margin: 0px; background-color: rgb(60,60,60) }
a:link { font-weight: bold; color: rgb(60,60,180); }
a:hover {color: rgb(180,60,60); }
</style>
</head>
<body>
<div style="margin: 100px auto; padding: 30px; border: solid 20px rgb(20,20,20); font-size: 16px; color: rgb(60,60,60); width: 550px; background-color: white;">
<span style="font-weight: bold; font-size: 28px;">request not found</span>
<br /><br /><br />(oops)
<br /><br />it appears you were looking for
<br /><span style="font-weight: bold;"><?php echo $_SERVER['HTTP_HOST'].$_SERVER['REQUEST_URI']; ?></span>
<br /><br />however, since you are here, it is clear you did not get what you wanted.
<br /><br />the problem has been reported so any broken links can be found and repaired.
<br /><br />you can click <a href="javascript:history.go(-1)">here</a> to go back to your previous page.
</div>
</body>
</html>
