// this script creates a watermarked image from an image file - can be a .jpg .gif or .png file
// where watermark.gif is a mostly transparent gif image with the watermark - goes in the same directory as this script
// where this script is named watermark.php
// call this script with an image tag
// <img src="watermark.php?path=imagepath"> where path is a relative path from the document root - such as subdirectory/image.jpg
$imagesource = $_SERVER['DOCUMENT_ROOT']."/".$_GET['path'];
if (!file_exists($imagesource)) die();
$filetype = strtolower(substr($imagesource,strlen($imagesource)-4,4));
if($filetype == ".gif") $image = @imagecreatefromgif($imagesource);
if($filetype == ".jpg") $image = @imagecreatefromjpeg($imagesource);
if($filetype == ".png") $image = @imagecreatefrompng($imagesource);
if (empty($image)) die();
$watermark = @imagecreatefromgif('watermark.gif');
$imagewidth = imagesx($image);
$imageheight = imagesy($image);
$watermarkwidth = imagesx($watermark);
$watermarkheight = imagesy($watermark);
$startwidth = (($imagewidth - $watermarkwidth)/2);
$startheight = (($imageheight - $watermarkheight)/2);
imagecopy($image, $watermark, $startwidth, $startheight, 0, 0, $watermarkwidth, $watermarkheight);
header("Content-type: image/jpeg");
imagejpeg($image);
imagedestroy($image);
imagedestroy($watermark);
You can then make the original images inaccessible if you put the following lines in a .htaccess file in the directory with the images:
RewriteEngine On
RewriteCond %{REQUEST_URI} !error.gif$
RewriteRule \.(gif|jpg|png)$ /error.gif [L]
