A little used farm road intersects with a multi-lane highway; a traffic
light controls the traffic at the intersection.
The light controller is implemented to maximize the time the highway light
remains green. A submodule implements a timer, which outputs "short" and
"long" time outs. The highway light stays green for at least "long" time.
Any time after "long" time, if there is a car waiting on the farm road, then
the farm light turns green. The farm light remains green until there are no
more cars on the farm road, or until the long timer expires. The yellow
light for both directions stays yellow for "short" time.
The timer has non-determinism in it. Liveness properties won't pass until
fairness constraints are placed on the timer, so that it can't pause
forever.
* Symbolic variables.
typedef enum {YES, NO} boolean;
typedef enum {START, SHORT, LONG} timer_state;
typedef enum {GREEN, YELLOW, RED} color;
* Module main ties together the underlying modules. In addition, it
* ORs together the start timer outputs of the farm road and highway
* controllers. Note that only a single timer is used for both the farm
* road and highway controllers. In theory, this could lead to conflicts; as
* implemented, such conflicts are avoided.
module main(clk);
input clk;
color wire farm_light, hwy_light;
wire start_timer, short_timer, long_timer;
boolean wire car_present;
wire enable_farm, farm_start_timer, enable_hwy, hwy_start_timer;
assign start_timer = farm_start_timer || hwy_start_timer;
timer timer(clk, start_timer, short_timer, long_timer);
sensor sensor(clk, car_present);
farm_control farm_control(clk, car_present, enable_farm, short_timer, long_timer,
farm_light, farm_start_timer, enable_hwy);
hwy_control hwy_control (clk, car_present, enable_hwy, short_timer, long_timer,
hwy_light, hwy_start_timer, enable_farm);
endmodule
* There is a single, coupled sensor that detects the presence of a car
* in either direction of the farm road. At each clock tick, it non-
* deterministically reports that a car is present or not.
module sensor(clk, car_present);
input clk;
output car_present;
wire rand_choice;
boolean reg car_present;
initial car_present = NO;
assign rand_choice = $ND(0,1);
always @(posedge clk) begin
if (rand_choice == 0)
car_present = NO;
else
car_present = YES;
end
endmodule
* From the START state, the timer produces the signal "short"
* after a non-deterministic amount of time. The signal "short"
* remains asserted until the timer is reset (via the signal "start").
* From the SHORT state, the timer produces the signal "long"
* after a non-deterministic amount of time. The signal "long"
* The following Buchi fairness constraints should be used:
* !(timer.state=START);
* !(timer.state=SHORT);
module timer(clk, start, short, long);
input clk;
input start;
output short;
output long;
wire rand_choice;
wire start, short, long;
timer_state reg state;
initial state = START;
/* short could as well be assigned to be just (state == SHORT) */
assign short = ((state == SHORT) || (state == LONG));
assign long = (state == LONG);
if (start) state = START;
else
begin
case (state)
START:
if (rand_choice == 1) state = SHORT;
SHORT:
if (rand_choice == 1) state = LONG;
/* if LONG, remains LONG until start signal received */
endcase
end
end
endmodule
* Farm light stays RED until it is enabled by the highway control. At
* this point, it resets the timer, and moves to GREEN. It stays in GREEN
* until there are no cars, or the long timer expires. At this point, it
* moves to YELLOW and resets the timer. It stays in YELLOW until the short
* timer expires. At this point, it moves to RED and enables the highway
* controller.
module farm_control(clk, car_present, enable_farm, short_timer, long_timer,
input clk;
input car_present;
input enable_farm;
input short_timer;
input long_timer;
output farm_light;
output farm_start_timer;
output enable_hwy;
wire short_timer, long_timer;
wire farm_start_timer;
wire enable_hwy;
wire enable_farm;
color reg farm_light;
initial farm_light = RED;
assign farm_start_timer = (((farm_light == GREEN)
&& ((car_present == NO) || long_timer))
(farm_light == RED) && enable_farm);
assign enable_hwy = ((farm_light == YELLOW) && short_timer);
case (farm_light)
GREEN:
if ((car_present == NO) || long_timer) farm_light = YELLOW;
YELLOW:
if (short_timer) farm_light = RED;
RED:
if (enable_farm) farm_light = GREEN;
endcase
end
endmodule
* Highway light stays RED until it is enabled by the farm control. At
* until there are cars and the long timer expires. At this point, it
* timer expires. At this point, it moves to RED and enables the farm
* controller.
module hwy_control(clk, car_present, enable_hwy, short_timer, long_timer,
input clk;
input car_present;
input enable_hwy;
input short_timer;
input long_timer;
output hwy_light;
output hwy_start_timer;
output enable_farm;
wire hwy_start_timer;
wire enable_farm;
wire enable_hwy;
color reg hwy_light;
initial hwy_light = GREEN;
assign hwy_start_timer = (((hwy_light == GREEN)
&& ((car_present == YES) && long_timer))
(hwy_light == RED) && enable_hwy);
assign enable_farm = ((hwy_light == YELLOW) && short_timer);
case (hwy_light)
GREEN:
if ((car_present == YES) && long_timer) hwy_light = YELLOW;
YELLOW:
if (short_timer) hwy_light = RED;
RED:
if (enable_hwy) hwy_light = GREEN;
endcase
end
endmodule
- It is currently Wed Nov 11, 2026 7:01 pm
Verilog Code for Traffic Light Controller
