How to Unblock Skype in Blocked Regions
Post by Neo » Thu Nov 19, 2009 3:11 am
How to unblock Skype in blocked regions (For Free)
Also,
How to anonymously browse internet
STEP 1:
Download Free VPN
STEP 2:
Install software to your PC as instructed
STEP 3:
Make sure you are connected to the internet. Press Connect.
STEP 4:
Select one option from the list as in the following image
STEP 5:
Check that you get authenticated correctly as in the following image
STEP 6:
Now you'll get following messages on the screen
Establishing connection to the server...
Authentification...
Authentification complete
Your internal network IP: 10.11.0.65
Connection established, good luck in surfing!
At the same time, following message will appear in system tray as in the following image.
You are now surfing the internet anonymously which will enable to you to browse any blocked content.
How to Unblock Internet Access in Blocked Regions
Post by Neo » Sat Nov 28, 2009 2:34 pm
You may also use Hotspot Shield. It is also a free software and someone told me it works great.
http://anchorfree.com/downloads/hotspot-shield/
Re: How to Unblock Skype in Blocked Regions
Post by Neo » Sat Nov 28, 2009 2:42 pm
There are some other free VPN services. You might have to try everything in this topic to get one working for you :D
  1. AlonWeb
    AlonWeb uses the OpenVPN software which is malware free. So it’s pretty safe to use AlonWeb VPN service. Just download the OpenVPN client software below and then download the Alonweb certificate and configuration file.
    Copy the configuration file in the config folder in OpenVPN installation directory.
    Now register for a new user account on AlonWeb VPN service.
    Connect through OpenVPN using the username and password which you just registered.
  2. UltraVPN
    UltraVPN is similar to AlonWeb. It is also based on OpenVPN service. It is also very easy to use. Just download the UltraVPN client from below and register for UltraVPN service here. Right click the UltraVPN icon placed in the status bar and select connect.
  3. JAP
    JAP is the VPN service I mostly use now. JAP is a german service so the IPs assigned to the JAP user will be Germany based. JAP software can be downloaded below. It doesn’t require any username or password. Just install the software, run it and enjoy anonymous connectivity to the internet.
  4. PacketiX.NET
    PacketiX.NET is the latest of my finds and works pretty well. But the problem is that it is a commercial software but the trial version is available. So it can be used freely without purchasing it. Just download the VPN connection manager from below and install it and make a new VPN connection in the connection manager and surf the web through PacketiX.NET VPN service.
