Here you can find the way of interfacing SHT7x (SHT71, SHT75) Humidity and Temperature Sensor
to a Microcontroller. This sensor gives very accuracy relative humidity values and temperature values.
I have tested the given code with PIC 16F877 MCU , and it worked fine
Data Sheet
Sample Code
Interfacing a Humidity Sensor with Microcontroller
