TCS34725 RGB Colour Recognition Sensor Module for Arduino
PIC16F1823 Microcontroller Development Board Module CJMCU-1286
1.5V Battery LR41 AG3 392A
MLX90614 Contactless Temperature Sensor Module GY-906
RC522 13.56Mhz SPI RFID Reader Writer Module Small
RC522 13.56Mhz I2C RFID Reader Writer Module Small
24C256 I2C EEPROM Memory Module
RCWL-0516 Microwave Radar Module Human Body Induction
APDS-9960 Proximity Non-contact RGB Gesture Module GY-9960
PCF8575 16-bit I2C I/O Extension Module for Arduino
USB To RS232 Adapter
HTU21D Temperature and Humidity Sensor Module HTU2X
Neodymium Magnet Rare Earth N35 4x4x1mm Cuboid
Neodymium Magnet Rare Earth N35 4x4x3mm Cuboid
Neodymium Magnet Rare Earth N35 5x5x2mm Cuboid
Neodymium Magnet Rare Earth N35 10x5x1.5mm Cuboid
Neodymium Magnet Rare Earth N35 10x2x2mm Cuboid
Neodymium Magnet Rare Earth N35 15x5x2mm Cuboid
Neodymium Magnet Rare Earth N50 2x1mm Cylinder
Neodymium Magnet Rare Earth N50 2x2mm Cylinder
Neodymium Magnet Rare Earth N50 3x1mm Cylinder
Neodymium Magnet Rare Earth N50 3x3mm Cylinder
Neodymium Magnet Rare Earth N35 4x1mm Cylinder
Neodymium Magnet Rare Earth N50 5x1.5mm Cylinder
Neodymium Magnet Rare Earth N52 8x1mm Cylinder
Miniature Ball Bearings Steel 3x8x4mm 693ZZ
Console Cable RJ45 To DB9 Cisco 72-3383-01
LD3320 ASR Speech Voice Recognition Module MP3 Playback SPI
ADUM1201 Magnetic Isolator Module Replace Optocouplers CJMCU-1201
CD4066B CMOS Quad Bilateral Switch
CD4047B Low Power Monostable/Astable Multivibrator
Barcode Scanner Module High Accuracy CCD USB EP1000 IP54
AMG8833 IR 8x8 Thermal Imager Array Temperature Sensor Module
SPCE061A Voice Recognition Module for Arduino
Thermal Receipt Printer 58mm USB Serial TTL/RS232
5V 5A SMPS Power Supply Metal Casing
24V 2A SMPS Power Supply Metal Casing
4V 300mA Battery 24x18x40mm (Normal)
4V 1200mA Battery 34x20x90mm (Normal)
Stereo Male to Dual Female Stereo Y Splitter Audio Cable 3.5mm
Male to Female Stereo Adapter Mic Converter (6.5mm to 3.5mm) Gold
Vero Board Line Small 5x7cm
Vero Board Dot Big 24x10cm
3.7V 850mAh Lipo Battery
4V 4A Rechargeable Battery 45x45x95mm
1.5V AA Battery Alkaline 2pcs (Good Quality)
1.5V AAA Battery Alkaline 2pcs (Good Quality)
3.7V Single Battery Charger 18650 500mA
390uF 400V Capacitor
4 Ohm 50W Speaker 5 inch
8 Ohm 50W Speaker 4 inch
8 Ohm 50W Speaker 6 inch
22pF Ceramic Capacitor
Micro Limit Switch without Lever 16A 250VAC
10D471K 470V Metal Oxide Varistor Resistor VDR
2SD1047 NPN High Power Epitaxial Planar Transistor
2SC1815 NPN Transistors
MJE13002 NPN Epitaial Transistors
D2627 NPN Si Transistor Color TV Horizontal Deflection
Repair Service (10x)
Project Support (Per hour)
Transparent Robot Wheel Tyre 2.5x55mm
Nextion 3.5 inch Enhanced HMI Intelligent Serial LCD Module Display
Gear Motor 3V 30RPM N20
Gear Motor 3V 50RPM N20
2-Way Mini JST 2.0 PH Connector Wire microbit
NodeMCU D1 Mini Lua WIFI WeMos 4M ESP8266 Module
Yellow Tyre Wheel for Small Smart Car D:35mm
9V Battery Clip Snap Connector with Male Barrel Jack
USB Host Shield for Arduino (Supports Android ADK)
Mini Solar Battery Charging Module LiPo CN3065 Input 4.4-6V Out 500mA
Mini Solar Panel 6V 1W 110x60mm
0.96 inch 128X64 OLED Display Module I2C IIC Serial Blue Yellow
Gear Motor 3V 100RPM N20
TL494CN Switching PWM Controller
2SD1047 High Power NPN Epitaxial Planar Bipolar Transistor
5A Protection Board for 7.4V 8.4V 18650 Li-ion Lithium Battery 2S
TJA1050 CAN Module
2SC5200 NPN Epitaxial Silicon Transistor
Seven Decade Programmable Resistor Board 1R - 9999999R 1/2W 1 0V Step Accuracy 1R
Battery Holder Case 2xAAA 3V PH2.0 for Micro:bit Microbit
Microbit Case Enclosure Blue
JWS-D6 Microwave Radar Module VDC 10M 180 Degree Angle Human Body Induction
HM-11 CC2541 Bluetooth 4.0 BLE Uart Transceiver Module JDY-10 With Adapter
Yellow Colour Tact Cap for Tactile Push Button Switch Momentary 12 x 12 x 7.3mm
Ash Colour Tact Cap for Tactile Push Button Switch Momentary 12 x 12 x 7.3mm
2SC3679 NPN Transistors
FDP047AN08 N-Channel PowerTrench MOSFET 75V 80A
HA12010 Fluorescent Tube Driver for Bargraph Display
ST13003-K MJE13003 High Voltage Fast-switching NPN Power Transistor 400V 1.5A
TL494 Adjustable PWM Controller Module 500-100kHz 5V 250mA
MPU9250 9-DOF 3-Axis Acceleration Gyroscope Magnetometer
Electromagnet 5Kg 5V P25/20 Holding Lifting
Electromagnet 2.5Kg 5V P20/15 Holding Lifting
Battery Lug Small Blade Female Spade Connector FDD1.25-110(5) 22-16 AWG
BD136 PNP Power Transistor 45V 1.5A
10D330K 33V Metal Oxide Varistor Resistor VDR
3M RFID Coin Sticker Cards 125 Khz 25mm TK4100 EM4100
Electric Solenoid Valve Angle L-shape 0.5-inch 12VDC NC Plastic Water Air
TRONIC.LK Item List 2201-2300
Post by TRONICLK » Mon Mar 11, 2019 4:23 am
