XT60 Male Female Bullet Connectors Plugs for RC Lipo Battery Drone Quadcopter
T Plug Male Female Deans Connector for RC LiPo Battery Quadcopter Drone
L Bracket for Gear Motor 25mm Metal
DIY LED Kit Water NE555 CD4017
DIY LED Kit Breath Light LM358
DIY LED Kit Flash Dual Colour CD4017
HDMI to Mini HDMI Joiner Socket
Motion Tilt Vibration Sensor SW-520D Metal Ball (Only sensor)
Light Control Endstop Limit Optical Switch Module
Mini Dual DC H-Bridge Speed Controller Motor Driver Module 2-10VDC MX1508
2RCA to Mic Converter (RCA to 6.5mm)
37 in 1 Sensor Module Kit for Arduino (Without plastic case)
2CL77 High Voltage Diode 5mA 20kV
Gear Motor 12V 1000RPM N20
Gear Motor 12V 1200RPM N20
10K Slider Potentiometer Behringer Mixer Fader Double Straight 75mm
CNY70 Reflective Optical Sensor with Transistor Output
Vernier Caliper Plastic 150mm 6 inch
Micro USB Socket Male DIY 5-pin
Microchip PIC18F4520
UC3845AN High Performance Current Mode Controller
NE555 General Purpose Single Timer SOP
MQ-9 LPG CH4 CO Carbon Monoxide Gas Sensor Module
ESP8266 ESP-12E WiFi Transceiver Wireless Module (Only Chip)
ADS1115 ADC DAC 16bit Precision Module BOGI
WS2812 5050 RGB LED Module 16-Bit 5V Ring
WS2812 5050 RGB LED Module 2x2 4-Bit 5V
WS2812 5050 RGB LED Module 4x4 16-Bit 5V
Ultrasonic Sensor Bracket HC-SR04 HY-SRF05 HC-SR05
MH-Z14A Infrared Carbon Dioxide CO2 Sensor Module 0-5000ppm
LED TV Backlight Tester with Current Voltage Display 0-320V
ESC Servo Tester CCPM 3 Channel 3 Mode
Dual MOSFET Driver Module PWM 15A 400W D4184 XY-MOS
PCM2704 MINI USB Sound Card DAC Decoder Board 5V 3.5mm
PCM2704 USB Sound Card DAC SPDIF Decoder Board 3.5mm
50Kg Load Cell Weighing Scale Sensor Half-bridge
Female Barrel Jack to Micro USB Socket Connector 5.5x2.1mm
KBU808 8A 800V Bridge Rectifier
NTC MF52-103/3435 10K ohm 1% Thermistor Temperature Sensor
NTC 10D-11 Thermistor Temperature Sensor
NTC 5D-15 Thermistor Temperature Sensor
X9C104P Digital Potentiometer Variable Resistor
ADXL362 Triple Digital Accelerometer Module for Arduino
Slot Type IR Infrared Speed Sensor Encoder Module LM393 Mouse
USB Microphone with Stand
DB15 Male Socket D-Sub VGA 15-pin 3-row Solder Type
DB15 Female Socket D-Sub VGA 15-pin 3-row Solder Type
WS2812 5050 RGB LED Module 8-Bit 5V Line
Obstacle Avoidance Sensor IR Infrared Module
T-Shaped Breakout Expansion Board with 40Pin GPIO Cable Raspberry Pi
104J 0.1uF 100nF 2000V 2KV Metallized Polypropylene Film Capacitor (Pitch 25mm) CBB81
STM32F103C8T6 STM32 ARM Minimum System Development Board
USB Microphone Dongle Raspberry Pi PC
24C32 Serial 32K EEPROM
24C256 Serial 32K EEPROM
24C512 Serial 512K EEPROM (2FB)
24C512 Serial 512K EEPROM (2FC) SMD
24C1024 Serial 1024K EEPROM (2GB) SMD
ST091Y SS24E01-G5 Slide Switch Vertical 10-pin 4-position 2P4T DP4T
Liquid Water Level Sensor Horizontal Float Switch 100V
2SK2645 N-Channel MOSFET 600V 9A
Battery Holder Case for 4x18650
3.7V 180mAh Lipo Battery
3.7V 1000mAh Lipo Battery Drone Quadcopter
Solder Flux Injection Type NC-559-ASM-UV (TFP) 10ml
33uF 400V Capacitor
47uF 400V Capacitor
2.2uF 100V Capacitor
STK4192-II Stereo Power Amplifier 50Wx2
FR4 Single Side Copper Board Strip (Approx L:340mm W:130mm)
NE-799 400W Stereo Amplifier USB/SD/FM/MP3 220VAC/12VDC
NED 40W Stereo Amplifier USB/SD/FM/MP3 12VDC Lotto
2.2 Ohm 1W Resistor 5%
2.2 Ohm 2W Resistor 5%
Gear Motor L Shape (No Wheel)
Vero Board Dot (Mini)
D882 NPN Transistor
FQP13N50 N-Channel MOSFET 500V 12.5A
P13N60 N-Channel MOSFET 650V 11A
FQP13N10 N-Channel MOSFET 100V 12.8A
IRFP264 HEXFET Power MOSFET 250V 38A
24C64 Serial 64K EEPROM
24C128 Serial 128K EEPROM
24C32 Serial 32K EEPROM SMD
24C64 Serial 64K EEPROM SMD
24C128 Serial 128K EEPROM SMD
24C256 Serial 256K EEPROM SMD
CD4511BE BCD to 7-Segment Latch Decoder Driver
CD4040BE 12-Stage Ripple-Carry Binary Counter/Divider
K10A60D N-Channel MOSFET 600V 10A
Miniature DPDT 2P2T 6 Pin Vertical DIP Slide Switch 9x4x3.5mm
RCA Female to 6.35mm Male Mono Jack (Silver)
RCA Female to 6.35mm Male Mono Jack (Gold)
SSD HDD Caddy Enclosure 9.5mm Small Type
SSD HDD Caddy Enclosure 12.7mm Large Type
MQ-135 Air Quality Benzene Alcohol Smoke Hazardous Gas Detection Module
Optical Infrared Water Liquid Level Sensor
Water level Sensor Float switch 110V PFS6210 PP
Water level Sensor Float switch Small PP
NTC 10K ohm 1% Thermistor Temperature Sensor with 1m Cable
TRONIC.LK Item List 2101-2200
Post by TRONICLK » Mon Mar 11, 2019 4:22 am
