SIM800L Quad-Band GSM GPRS module with Antenna V2.2 5V for Arduino
Mini Ublox NEO-6M GPS Module Aircraft Flight Controller for Arduino
MP3 Player YX5300 UART Control Serial Module
Power Bank Case for 2x18650 Batteries (Without Battery) DIY
Power Bank Module 5VDC 1A Single USB 3.7V 18650 T6864-C V2.0
Power Bank Module 5VDC 2A Dual USB 3.7V 18650 BLY-03 V1.2
Power Bank Module 5VDC 2A Dual USB 3.7V 18650 XHD-2310H
Raspberry Pi 3 Model B+
Raspberry Pi Zero W V1.1
Raspberry Pi 3 Red White Enclosure Box Original
Raspberry Pi Zero Red White Enclosure Box Original
Raspberry Pi 3 Black Enclosure Box
Raspberry Pi Zero Acrylic Enclosure Box
5VDC 1 Way 1 Channel SSR Solid State Relay Module OMRON G3MB-202P
5VDC 2 Way 2 Channel SSR Solid State Relay Module OMRON G3MB-202P
5VDC 4 Way 4 Channel SSR Solid State Relay Module OMRON G3MB-202P
5VDC 8 Way 8 Channel SSR Solid State Relay Module OMRON G3MB-202P
Teensy 2.0++ USB AVR Development Board AT90USB1286
DS0150 15001K Digital Oscilloscope DIY with Housing
1.55V AG10 LR1130 389 G10 Alkaline Battery (Normal)
Digital Audio Optical Cable 3m
1604 16x4 Blue Backlight LCD Display
VS1053B MP3 Music Shield with MicroSD TF Card Slot
Stereo Jack 3.5mm 4 Pole Male (Good Quality)
Digital Audio Optical Cable 1m
USB to SATA/PATA/IDE Adapter For 2.5/3.5 inch Hard Disk Drive with Power Adapter
M27C160-100F1 EPROM UV 16MBIT M27C160
USB WIFI Dongle 300Mbps
Si4703 RDS FM Radio Tuner Evaluation Module
Motion Tilt Vibration Sensor Module SW-42
5 Way Flame Detector Module Board
Digital Voltmeter 100V 3 Wire LED Display
Micro 2 Phase 4 Wire Stepper Motor 9T with Copper Gear
USB HUB 4-port USB2.0
MP3 Player Kids
Stereo To Stereo AUX Audio Cable 1m
Stereo Jack Mic 6.5mm (Normal)
50k Volume Control (Stereo)
100k Volume Control (Stereo)
1K Rotary Wirewound Precision Potentiometer Variable Resistor 3590S-2-102
5K Rotary Wirewound Precision Potentiometer Variable Resistor 3590S-2-502
10K Rotary Wirewound Precision Potentiometer Variable Resistor 3590S-2-103
50K Rotary Wirewound Precision Potentiometer Variable Resistor 3590S-2-504
100K Rotary Wirewound Precision Potentiometer Variable Resistor 3590S-2-104
Ash Colour Tact Cap for Tactile Push Button Switch Momentary 12 x 12 x 7.3mm
Yellow Colour Tact Cap for Tactile Push Button Switch Momentary 12 x 12 x 7.3mm
12VDC Relay 250VAC 20A G4A-1A-E-CN
24VDC Relay 250VAC 17A G4A-1A-E-CN
Small Plastic Pulley Wheel
STK4191-II Stereo Power Amplifier 50Wx2
2SC4429 Silicon NPN Power Transistor 1100/800V 8A 60W
DB9 Male Socket D-Sub RS232
DB9 Female Socket D-Sub RS232
3.7V 1000mAh Lipo Battery JST-Plug for Drone Quadcopter RC
SIM7000C 4G NB-IoT / 4G eMTC / EDGE / GPRS / GNSS LTE Module
Raspberry Pi 3 Clear Acrylic Enclosure Box with Cooling Fan
5 inch 800x480 HDMI TFT LCD Touch Screen for Raspberry Pi 3 Model B/ B+
Servo Motor Metal Wheel MG90 Full Set
Servo Motor Metal Wheel MG996 Full Set
Digital Audio Optical Cable 2m
WS2812 5050 RGB LED Module 1-Bit 5V Square
WS2812 5050 RGB LED Module 1-Bit 5V Round
WS2812 5050 RGB LED Module 8x8 64-Bit 5V
PWM Motor Speed Controller 13KHz 12-40VDC 10A NE555
ESC 30A Electric Speed Controller BEC 5V 3A for 2-4S Simonk Firmware
Power Bank Module 5VDC 2.1A Single USB 3.7V 18650
Power Bank Module 5VDC 2.1A Triple USB 3.7V 18650
Power Bank Module 5VDC 1A / 2.1A Dual USB 3.7V 18650
FPV Camera Mic Wide Angle PAL 600TVL 1/4 1.8mm Lens 170 Degree CCD
3A Protection Board for 3.7V 18650 Li-ion Lithium Battery
FR107 Diode 1A 1000V
STM8S103F3P6 STM8 ARM Minimum System Development Board
Flame Detector Alarm Relay Module Board 12VDC
TP4056 5V 1A Micro USB 18650 Lithium Battery Charging Module (With Protection)
500GB SATA Hard Disk
TDA7718 Audio Signal Processor 3 Channel
TEC1-12709 DC12V 100W Peltier Thermoelectric Cooler
BTS7960B Half Bridge Motors Driver DC (Genuine)
FPV Camera Mic PAL 700TVL 2.8mm Lens CCD
STLink ST-Link V2 Mini USB Emulator Downloader STM8 STM32
RDA5807M RRD-102V2.0 FM Stereo Radio Module
HC-12 SI4463 433MHZ High Power Wireless Transceiver Arduino
1.5V AG10 LR1130 389 G10 LR54 GP189 Alkaline Battery (Maxell)
Microchip PIC12F508 I/P
Digital Vernier Caliper 150mm 6 inch
Flame Detector Infrared IR Module
Altera Mini USB Blaster for CPLD FPGA NIOS JTAG Programmer
NE555 Signal Generator Stepper Motor Driver
Analog Voltmeter Panel Mount 0-300VAC 91L16
P75-B1 D-1.02mm Spear Spring Loaded Test Probe Pin
F Type Female To TV Aerial RF Coaxial Male Connector
LED Bar Graph Display Yellow 10 Segment Ultra Bright KYX-B10Y
LED Bar Graph Display Green 10 Segment Ultra Bright KYX-B10G
LED Bar Graph Display Red 10 Segment Ultra Bright 2510BS
LED Bar Graph Display 4 Colour 10 Segment Blue Green Yellow Red
LED Bar Graph Display Battery 4 Colour 10 Segment Blue Green Yellow Red
Soil Humidity Hygrometer Moisture Detection Sensor Module for Arduino
RU190N08R N-Channel Advanced Power MOSFET 80V 190A
RU190N08Q N-Channel Advanced Power MOSFET 80V 190A
TRONIC.LK Item List 2001-2100
Post by TRONICLK » Mon Mar 11, 2019 4:21 am
